Looking for a macro lens. My signature shows what I own right now.
Nov 18, 2014 17:54 | #1 Looking for a macro lens. My signature shows what I own right now. _______________
LVMoose Moose gets blamed for everything. More info | Nov 18, 2014 17:56 | #2 What do plan on shooting, bugs, jewelry.... ? Moose
Nethawked Senior Member More info | Nov 18, 2014 18:13 | #3 I happen to think like LV Moose.
cali92rs Member 179 posts Likes: 16 Joined Oct 2014 Location: Long Beach, CA More info | Nov 18, 2014 22:14 | #4 What is your budget? Shooting bugs which you would want a longer working distance? Or other subjects where you can get nice and close? Going to be macro specific or more general purpose? 6D, 16-35mm f4L IS, 24-105mm f4L, 50mm f1.8 STM, 135mm f2L, Tamron 70-300mm VC
Archibald You must be quackers! More info | Nov 18, 2014 23:47 | #5 Frodge wrote in post #17280191 Looking for a macro lens. My signature shows what I own right now. Wow, does your ISP charge by the word? Canon R5 and R7, assorted Canon lenses, Sony RX100, Pentax Spotmatic F
I have the Canon 60/2.8 on crop but I am planning on upgrading to the 100L although the Tamron 90 VC hasn't been ruled out yet. I am only planning on upgrading because I am prepping a FF move otherwise I wouldn't bother. Canon 7D/350D, Σ17-50/2.8 OS, 18-55IS, 24-105/4 L IS, Σ30/1.4 EX, 50/1.8, C50/1.4, 55-250IS, 60/2.8, 70-200/4 L IS, 85/1.8, 100/2.8 IS L, 135/2 L 580EX II, 430EX II * 2, 270EX II.
iroctd Senior Member 343 posts Likes: 66 Joined Aug 2013 Location: East coast More info | Nov 19, 2014 05:54 | #7 FEChariot wrote in post #17280795 You can get some where around 2.4 times life size with a 60/2.8 and a full set of Kenko tubes but you can't get over 2x with a 100L using the same tubes. But you can add a 1.4x teleconverter to the 100L with tubes and get 2.8x. I also believe you will end up with more working distance with the 100mm focal length and the teleconverter.
Nov 19, 2014 07:44 | #8 iroctd wrote in post #17280952 But you can add a 1.4x teleconverter to the 100L with tubes and get 2.8x. I also believe you will end up with more working distance with the 100mm focal length and the teleconverter. Interesting. Third party TC though right? It won't take the Canon ones will it? Canon 7D/350D, Σ17-50/2.8 OS, 18-55IS, 24-105/4 L IS, Σ30/1.4 EX, 50/1.8, C50/1.4, 55-250IS, 60/2.8, 70-200/4 L IS, 85/1.8, 100/2.8 IS L, 135/2 L 580EX II, 430EX II * 2, 270EX II.
Nov 19, 2014 10:17 | #10 LV Moose wrote in post #17281097 I've also coupled my 100L with a set of Kenko tubes and a 1.4X TC (Kenko) to get close to 3:1. Works fine, but you get a really thin DoF and it takes a lot of light. Better have a flash set-up. Do you need to place the TC right to the lens or can you stack the tubes inbetween? I was thinking this might be a way to get around the short back focus plastic peice on the 60/2.8 that prevents any TC from being mounted to EF-S lenses. If so then the 60.2,8 witha Kenko would give greater than 3X right? or would that just not work? Canon 7D/350D, Σ17-50/2.8 OS, 18-55IS, 24-105/4 L IS, Σ30/1.4 EX, 50/1.8, C50/1.4, 55-250IS, 60/2.8, 70-200/4 L IS, 85/1.8, 100/2.8 IS L, 135/2 L 580EX II, 430EX II * 2, 270EX II.
LVMoose Moose gets blamed for everything. More info | ^ I put the TC between the tubes and camera body. I rarely use this combination, except for extremely small critters such as spider mites or something like that. I usually find tubes + the 100mm sufficient, even on a full frame. On a crop it looks even closer, of course. I think you could skip the TC for now. Moose
Nov 19, 2014 10:58 | #12 LV Moose wrote in post #17281398 ^ I put the TC between the tubes and camera body. I rarely use this combination, except for extremely small critters such as spider mites or something like that. I usually find tubes + the 100mm sufficient, even on a full frame. On a crop it looks even closer, of course. I think you could skip the TC for now. Does it have to be that way? Will everything work if you put: body>TC>tubes>lens ? Assuming you have tubes that have electrical connections of course. Canon 7D/350D, Σ17-50/2.8 OS, 18-55IS, 24-105/4 L IS, Σ30/1.4 EX, 50/1.8, C50/1.4, 55-250IS, 60/2.8, 70-200/4 L IS, 85/1.8, 100/2.8 IS L, 135/2 L 580EX II, 430EX II * 2, 270EX II.
LVMoose Moose gets blamed for everything. More info | Nov 19, 2014 11:08 | #13 FEChariot wrote in post #17281402 Does it have to be that way? Will everything work if you put: body>TC>tubes>lens ? We're saying the same thing. TC between the tubes and camera body, body>TC>tubes>lens. Moose
Archibald You must be quackers! More info | Nov 19, 2014 11:14 | #14 Curious - why can't you use just the 1.4X (without extension tubes) with the 100mm? Canon R5 and R7, assorted Canon lenses, Sony RX100, Pentax Spotmatic F
| Latest registered member is semonsters 1294 guests, 135 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
