William R. Fleming wrote in post #17286752
i was looking in Amazon.com and they offer a Canon 100-400 packake deal (which i am not going to buy) the offer a Vivitar 2XMC4 AF ............do you think auto focus will work properly on the lens?
No! But see below.
gonzogolf wrote in post #17286776
The loss of autofocus has to do with max apertures on your setup. The lens zoomed to 400 is 5.6 wide open. The 1.4 reduces that by a stop, the 2x by 2 stops. So with a 1.4 mounted your lens-extender combo has a max aperutre of f8. Rebel bodies will not autofocus when the max aperutre is smaller than f5.6. It would work if you had a 1D series or some of the newer bodies.
This is true, with an if. If the TC is a reporting TC. Some off brands don't. If they do there is the taping of certain pins, so it does not report.
That said - (To the OP) doing this almost always results in poor to non-locking AF, so IMO it is not worth it.
Ultimately (IMO), just go with what gonzogolf said and suggested.
Reasonably priced 3rd party -
Tamron 150-600mm f/5-6.3
Sigma 50-500mm f4.5-6.3 (or one with same range but f/4-6.3 and no stabilization), 150-500mm f/5-6.3, & 150-600mm f/5-6.3
Tokina has non over 400mm that I am aware of!
IMO, go for one of the 600mm.
Do keep in mind the zooms with 500/600 tele ends are big. You might need a new bag for carrying them. The Canon 100-400L (MKI) can fit in most bags, as it is actually shorter than any of the Canon 70-200mm f/2.8 lenses. Supposedly the MKII is shorter than the IS f/2.8s and the same length as the non-IS f/2.8.
I mention this because I've thought about switching out my 150-500 for the Canon, just because then I would probably carry it more frequently. Decided I'd rather have the extra 100mm and kept the Sigma. Then the Tamron followed by Sigma 600s came out, and thought about side/up-grading. Now that the Canon II has been announced, I'm waiting to see how it performs before a final decision.
