I'm new here but have now read a lot of threads and decided to yesterday, take 1/2 a day, and methodically go lens by lens, camera by camera and do a Dot-Tune, mico-focus, of each lens on each camera to see what I got.
First of all, mathematically I understand and get that there is a slightly larger area of critical focus behind the spot focused area than in front of the 'zeroed' spot so before I give the details of what I found, it would seem to me that Canon has chosen to set up their cameras with this 'mathematical fact' and all that I discovered is just the fact that Canon did this as oppose to 'equalizing' this PLANE of focus evenly (Forward and Aft). I did also find that a few lens lay outside this and always were in the same direction.
So, I have:
- two 5D3s
- a new 7D2
- L Primes (35 F1.4, 50 F1.2, 85 F1.2, 100 F2.8 macro, 135 F2, 200 F2.8)
- L zoomes (24-70 II, 70-200 II F2.8, 70-200 II F4.0)
I came across the Dot Tune Auto Focus Micro Adjustment method and decided to see if I could do it (it is easy) because I haven't been happy with all my lenses and I just wanted to know if they were good or not.
(The video I watched before I started)
https://www.youtube.com/watch?v=7zE50jCUPhM&hd=1![]()
I did a Google Search for Auto Focus Charts and printed off 2 identical charts that I put at two different spots to check initially if they would both give the same results as I wanted to make sure different lighting wasn't a factor - they were both the same after a few checks so I then set up 2 stations with taped off marks on the floor using (50 x Focal Length) as the distances to perform the Micro Focus Adjustments on for each lens.
Before I get to my findings, I want to say that every single lens fell within the area of critical focus - i.e. they were technically all 'sharp'. I did very quickly find that every single lens was NOT in the MIDDLE point of the plane of focus (it was forward of center - this has to be a Canon choice) but I did find a few, as I suspected, that while within the zone of being classified as Sharp, were on the very very edge of this plane (again all in the same biassed direction - FORWARD) so my final adjustment has put a smile on my face (like a fresh sharpening on a hockey skate or a fresh stringing on a tennis racket).
The second punch line I want to give is that if you shoot at F1.2 (as I do) on your 50L or 85L, trust me when I say this, do what I have done and test these lens, but also, when you get your results, think very carefully what they are saying, and what from a DoF perspective (forward and Aft) that you want and need for your photography (this is very important).
So, since not everyone is going to be familiar with this method, you are basically pushing your Micro adjustments both (Closer and Farther) until the camera can no longer achieve Focus Lock. This information then tells you your Zone of critical focus both in front of and behind your chosen spot focus target - you can then adjust each lens, to your desire, to have your desired DoF plane RANGE around your Spot Focus for each lens - the Math guy in me loves this approach as I think of it as a Normal Distribution around a Mean with a certain Standard Deviation. I was also interesting to see the differences between lenses and cameras, for my own education, what this range was (usually between 17 on the low-end and 24 on the high-end of Micro Adjustment increments is the RANGE of Critical Focus at 50 x Focal Length).
So, here is what I got (+3 means +3 micro adjustments were needed to center the range)
5D #1
- 35 F1.4 +3
- 50 F1.2 +3
- 85 F1.2 +9
- 100 F2.8 +7
- 135 F2 +10
- 200 F2.8 +8
- 24-70 F2.8 +4
- 70-200 F4 +4
- 70-200 F2.8 +8
5D #2
- 35 F1.4 +5
- 50 F1.2 +5
- 85 F1.2 +9
- 100 F2.8 +9
- 135 F2 +11
- 200 F2.8 +10
- 24-70 F2.8 +4
- 70-200 F4 +4
- 70-200 F2.8 +8
7D2
- 35 F1.4 +4
- 50 F1.2 +4
- 85 F1.2 +8
- 100 F2.8 +10
- 135 F2 +6
- 200 F2.8 +7
- 24-70 F2.8 +4
- 70-200 F4 +4
- 70-200 F2.8 +8
What does the above data say?
1) There is pretty clearly a choice by canon, that from a Depth of Field perspective, they chose to place more Depth of Field behind the Center Point of Focus because every single lens, on all three cameras, had to be moved Rearward by +3 to +4 to center the spot focus point between the front and rear points of critical focus
2) I also found it interesting that the 3 lens that appeared to need outsized Rearward adjustments to center the spot focus point were the 85 1.2, the 100 2.8 Macro and the 70-200 2.8. Again, after some thought about shooting style and why they might have done this (if it is deliberate) is that these 3 lens are probably the 3 that are used to construct Out Of Focus / critical planes of focus / close-ups and thus it appears they chose to deliberately have more of the sharp focus behind the spot focus point and maybe not to 'waste' critical focus area in front of the point (seems reasonable)
I now have my data for each lens and camera and I'm glad to have it. My 2 5Ds seem very close (maybe 1-2 micro adjustment points apart), the 7D2 seems to fall exactly in the middle of the 5Ds and all my lenses were technically sharp.
What did I decide to do with this information?
- it is all stored per lens in each camera so they will automatically 'center' the spot focus area within the plane
- but, since it is very easy to go into the menu and disable the correction, it is easy to do for lens such as the 85, 100, 70-200 if I want to move each of these lens spot focus point to the very front of the focal plane
- for the 85 at 1.2, this is the lens that I noticed the most, along with the 50 but on the 85 there is huge difference, the lens is now sharper as before it was on the absolute edge of being in focus / not in focus and you could tell with your eye that it could be sharper - and now - WOW - it is way f'ing sharper - VERY happy about this
The other interesting fact that I found, and I haven't completely come to grips with its meaning, is that on the 7D2 versus the 5D3s, it can either be statistical noise (don't think so), but for the 135 F2 and 200 F2.8, both required less adjustment at the 50 x Focal Length distant point to center the spot focus point within the focal plane that the 5D3s did - I wonder if this is an issue of higher pixel density being and allowing finer focus on the 7D versus the 5D
Hope some of this information is useful.
Paul
