I have a Nissin Di466 that is behaving. I don't know how to troubleshoot.
When I put my camera (5D) on P mode, or green box and I use the Nissin Di466 flash, I get images that are really dark. The histogram (show image in the camera, then press info) is non null only in the left half.
When I try the exact same setup using another flash (YongNuo) the image is well exposed (the histogram spread across the entire range).
The batteries are fresh. Both flash point in the same direction, etc.
I don't know what else to test, do you have any suggestions?
Is this the symptom of a dying lamp, dying capacitors, else?
