DionM wrote in post #17293590
I recently acquired one of these and need a tripod head solution.
I have a Acratech Ultimate and like it, so I naturally went to their site.
Their "Long Lens Head" looks interesting - anyone got one?
http://www.acratech.net …lens-heads/long-lens-head
I know the usual recommendation is a ballhead + Wimberley sidekick, but just thought I'd explore other options.
Having owned the 600 F4 L IS Mk1 for quite a while and now using the 800 F5.6 L IS I would not recommend anything other than a full Gimbal head. Anything else is going to be a compromise. Even the, much vaunted Uniqball has it's compromises - but it is very good!
Which Gimbal is best seems to be a matter of personal opinion. I use the Wimberley 2 and have, yet, to find anything as good - but I haven't tried them all! The Wimberley Sidekick is very good but it doesn't work so well with a lens as big as the 600, is very dependent on the quality of the ball head below it and does not allow vertical balancing of the lens - quite important if you use a 1 series of battery grips.
Have a look at the Wimberley site (my recommendation) but don't discount the larger Jobu and RRS gimbal heads as I hear good things about them too. Also, if possible, try them out first as some models (whist very strong) can have some vibration damping issues. If you have to buy blind then go for the Wimberley 2, it just works!
Life is for living, cameras are to capture it (one day I will learn how!).
