Thread started 01 Dec 2014 (Monday) 14:30
Big stopper or not
pelooyen
Dec 01, 2014 14:30 |  #1
I am heading to New Zealand next week and have a a few hundred dollars to spend
I have a CPL, 8ND and a 64ND which will go on my 17-40. Of course I can stack the two ND filters to give me 9 stops
Is there are strong argument for a Big Stopper, as I would like to do day time long exposures.
I don't have any GNDs as usually process HDR stuff.
So should I get a a GND set instead?
I have also been thinking of a Nerotrigger (or similar) to allow me to do lightning shots.
What would you consider most important?
cheers, Paul
Flickr (external link) | My Website (external link) | Like me on Facebook (external link)
6D | 5Dc | 17-40mm L | 28-135mm IS USM | 70-200L f4 | 100mm f2.8 macro USM | MPE65 | MT-24EX | 580EX | Kenko extension tubes | 1.4x TC
| couple of umbrellas and softbox and other lighting stuff
Harm
License to kill... a thread
Gallery: 13 photos
Dec 01, 2014 14:33 |  #2
The Big Stopper is negligible in weight, I would absolutely take mine if I were going to New Zealand.
What is your hesitation for not wanting to take it?
SmugMug (external link)
pelooyen
Dec 01, 2014 15:23 as a reply to  @ Harm's post |  #3
Simply that the two filter I have is already 9 stops and so could argue that it is a lot of money for an extra stop
cheers, Paul
KaosImagery
Gallery: 31 photos
Joined Sep 2009
Dec 02, 2014 12:10 as a reply to  @ pelooyen's post |  #4
If it's a really bright day, sometimes 9 or 10 stops isn't enough to bring your shutter speed down as low as you want. I stack my 2 stop and 3 stop grads on top of the Big Stopper in those situations. I guess it all depends on what you want out of a shot. I really like motion blur and if it's not that windy, I need longer shooting time on bright day to get that.
Website (external link) flickr (external link) FaceBook (external link)
pelooyen
Dec 02, 2014 23:55 as a reply to  @ KaosImagery's post |  #5
sounds good - I just ordered it, along with the foundation kit
Thinking of also a GND.
If only one, which would you suggest? Tossing between .6 soft or hard.
Should I stick to Lee or is there an siilar quality but cheaper option?
cheers, Paul
KaosImagery
Gallery: 31 photos
Joined Sep 2009
Dec 03, 2014 08:28 as a reply to  @ pelooyen's post |  #6
I am certainly not a filter expert, but I read that hard GNDs work best were there is a defined horizon line, like a seascape. I have the .6 and .9 soft Lee GNDs, which I found on POTN for a fair deal a while ago. The softs work well for me because I am mostly shooting in a hilly / mountainous area. Often the trees or land will be in the darkened area from the filter, but I can typically adjust 1-2 stops in Lightroom on those areas.
For me, the .9 gets more use as I tend to shoot around sunset and there is often 3 stops or more difference between the sky and foreground. I would like a reverse GND so the upper sky doesn't get as darkened...
I've read some reviews of less expensive filters, some sound pretty good, but when I came across the used Lees, I bought them.
Have a great trip, look forward to seeing your photos!
pelooyen
Jan 01, 2015 15:31 as a reply to  @ KaosImagery's post |  #7
Thanks. There are à couple of shot already on Flickr
cheers, Paul
dkizzle
Joined Mar 2012
Jan 02, 2015 11:23 |  #8
cutwater wrote in post #17307935 (external link)
You are correct about hard step GNDs BUT...when you stack hard step GND's to replace a Big Stopper you are covering entire lens and therefore horizon issue does not apply.
I want to guest blog on your Landscape / Travel photography blog, PM for details
cerett
Joined Jun 2013
Jan 11, 2015 18:53 |  #9
I would get a big stopper first and, if you still have some extra money, consider a set of soft GNDs. Be aware that in this digital age, a lot of photographers have gotten away from GNDs and rely mainly on post processing. However, I still carry a set of GNDs with me.
https://www.martinfeld​manphotography.com (external link)
3,060 views & 1 like for this thread, 5 members have posted to it and it is followed by 2 members.
Big stopper or not
1504 guests, 136 members online
