Thread started 01 Dec 2014 (Monday) 19:38
Help with still life of MTG cards
RazorbackSam
Dec 01, 2014 19:38 |  #1
My boss is a huge MTG player and has an extensive collection of cards. Believe it or not but some of them are worth thousands of dollars.
He is in negotiations with another collector to sell two cards for over $22k... Problem is the guy wants some really clean images of the cards and he's only able to get some with glare on them...
He's asked me to assist, problem being that I'm usually adding light to enhance the subject.
Suggestions?
[Canon 7D | 24-70mm 2.8 L | 70-200mm 2.8 IS L | 18-135 3.5~5.6 IS | 28mm 1.8 | 50mm 1.8 | Manfrotto 055XPROB Legs - 222 Head | Manfrotto 060B MonoPod
www.settlephotos.com (external link)
orisky
Dec 02, 2014 01:02 |  #2
I believe you. I have a few myself :)
I had the same issue trying to get good photos and eventually went the scanner route. But be very careful putting it on and off the scanner that you don't use your nails to pick it up. If you find a better option via a camera I'd love to hear about it!
Echo63
Dec 02, 2014 04:44 |  #3
What gear do you have ?
When i do "copy pics" for work (literally photographing a print)
I use a pair of speedlights.
I put the pic (or card in your case) down on a flat surface (table etc) then put a speedlite each side, on their little stands, with the bounce cards out (pointed at each other, about 4ft apart)
Turn the lights in the room off too
My Best Imageswww.echo63.deviantart.​com (external link)
Gear listhttps://photography-on-the.net …p?p=2463426&pos​tcount=385
RazorbackSam
Dec 02, 2014 22:43 as a reply to  @ Echo63's post |  #4
i've got a couple 600's... I could definitely set that up. Thanks for the suggestion!!
Assuming the use of a tripod to maintain aspect between cards?
armis
Joined Jan 2012
Dec 03, 2014 06:27 |  #5
Alternatively (and a bit more work required), you can also try cross-polarization.
Fuji X-T4, 18-55 and 55-200 zooms, Samyang 12
www.wtbphoto.com (external link)
Echo63
Dec 03, 2014 07:30 |  #6
RazorbackSam wrote in post #17307096 (external link)
You could do - i typically only shoot a pic or two at a time, so i just line it up using the grid in the 1DX viewfinder
adamfarl
Joined Feb 2012
Dec 03, 2014 10:11 |  #7
I have had some problems with board game boxes in the past....
I just ended up taking the pics at a steep angle and heavily diffused any light in my studio. Bounced it around the room a few times and everything turned out great.
Canon 6D | Canon 50 1.4 | Sigma 150-500 | Canon 17-40L
Traci_Ann
I'm a masochist
Gallery: 27 photos
Dec 03, 2014 15:35 |  #8
RazorbackSam wrote in post #17302403 (external link)
Suggestions?
Very believable... I have quite the collection also. I've been playing since Alpha release.
As for your problem, what about using a light tent? Like used in product photography.
Sevas Tra
Steelydan
Gallery: 23 photos
Jan 17, 2015 17:51 |  #9
You could use two continuous lights, as seen at the start of this Youtube clip for photo restoration.
https://www.youtube.co​m/watch?v=OnD9tU3UvFI (external link)
Slainte
John
steelbluesleepr
Feb 09, 2015 03:11 |  #10
Continuous vs flash makes no difference, to the sensor, light is light.
Whatever light you use just has to be at a oblique enough angle to not bounce at the camera. you can essentially just place a small makeup mirror in place of the card and if you can see the light source in the reflection, then you're going to get a glare. Now, this is just a rough guide, since the surface of the card isn't perfectly smooth and that slight matte finish will reflect/glare at slightly more of an angle than a mirror, but it will get you into the right ballpark.
-Jayson- my flickr (external link)
In the bag: 5D mark II+Vello grio/10d+grip/Canon 17-40L/Canon 28-135/Canon 50 1.8/Canon 35-80 Macro Conversion/Vivitar 135 2.8 M42/Vivitar 28 2.5 M42/Yongnuo YN460II x3/Yongnuo RF-602 x3
greyswan
I have just suddenly realised just how deranged I am
Gallery: 18 photos
Post edited over 8 years ago by greyswan.
Oct 16, 2015 05:00 |  #11
One of the simplest ways to eliminate glare from a flat reflective object, shooting straight from the front, is to get a large piece of matte black foam core and cut a round hole in the middle the exact size of the lens. Hang it on the lens close to the camera body, center the subject and shoot. Be exact with the placement and size of the hole for good balance of the board.
It's important that the board part facing the subject is black, not white, as white will bleach the color out, and reflect the black lens ring. The black also renders the contrast and color of the subject better.
I shoot glass-faced clocks as a product photographer, and this is really the best, the cheapest, and most time-efficient way to eliminate glare and reflections on flat faces. I actually hang a large 4' x 4'piece of black-painted coroplast from the lens for larger objects like our 35-inchers. The camera frame can easily handle the extra weight of the boards since they are designed to hold very heavy lenses.
Cheers, hope this helps
Chris
A clean house is a sign that my computer's broken...
gallery:https://ephemerastudio​.smugmug.com/ (external link)
Gear: 50D, 300 f4L, 70-200 f4L, 100 1.28 Macro, nifty fifty.
farmer1957
Gallery: 6 photos
Joined Jul 2012
Oct 18, 2015 22:19 |  #12
I photograph custom pool cues and billiard related products.
Some one mentioned cross polarization technic and personally I think they are right on.
Here is how it works
Polarized light is either transmitted as in the light is already polarized like florescent lighting.
To make any un polarized light source polarized it is ether transmitted refracted , reflected an or scattered .
So if your lighting is any of the above the light contains electromagnetic polarized waves ...
When electromagnetic polarized waves strike or comes in contact with all non metallic smooth surface it creates electromagnetic polarized reflection ......AKA glare .............
Cross polarization technic
You put linear polarized film over your soft boxes which filters out 1/3 of your lighting.
Then you use a CLP on your lens
IMAGE: http://i1110.photobucket.com/albums/h454/mortuarymike/019_zps31136acb.jpg
IMAGE LINK: http://s1110.photobuck​et.com …/019_zps31136ac​b.jpg.html  (external link)
IMAGE: http://i1110.photobucket.com/albums/h454/mortuarymike/IMG_0045_3_zps618f48ed.jpg
IMAGE LINK: http://s1110.photobuck​et.com …45_3_zps618f48e​d.jpg.html  (external link)
7,897 views & 1 like for this thread, 10 members have posted to it and it is followed by 5 members.
825 guests, 147 members online
