Thread started 03 Dec 2014 (Wednesday) 09:53
What mount question
jaomul
Joined Apr 2011
Dec 03, 2014 09:53 |  #1
Hi All,
I am putting together a few softboxes, umbrellas, stands and a bit more lighting kit (basic at the moment). I also like doing DIY stuff. My question is what is the best mount (most popular or recommended)? It seems the bowens s mount has a lot of options. At the moment I will be using speedlights, this may or may not change going fwd. Thanks
Olympus EM5,Nikon d7200,
Olympus 12-50mm, 40-150mm,17mm f2.8,Nikon 50mm F1.8, Tamron 90mm vc, 18-105mmVR, Sigma 18-35 f1.8
Qlayer2
OOOHHH! Pretty Moth!
Gallery: 24 photos
Joined Dec 2013
Dec 03, 2014 11:24 |  #2
The bowens mount is the most universal- you will find options from lots of manufacturers. Using it with speedlights works out great with the godox S-type brackets like this:
http://www.amazon.com …NC/ref=sr_1_1?i​e=UTF8&qid (external link)
You can also get speedrings for most monolights or strobe systems to use bowens mount accessories, if the ones you choose aren't designed for the bowens mount to begin with.
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Post edited over 8 years ago by gonzogolf.
Dec 03, 2014 11:36 |  #3
Forget which mount is most universal. Do some strategic planning toward your eventual goals. Do you want studio strobes? If so, what brand meets your needs and budget? Buying the most universal mount makes no sense if the stuff you get forces you to to buy strobes you dont wsnt. If you decide to stick ei with speedlites then just get speedlite modifiers. If you are going to get strobes like alien bee or Elincrome then buy modifiers in that mount.
jaomul
Joined Apr 2011
Dec 03, 2014 12:33 |  #4
Thanks both for your help
Whortleberry
Joined Dec 2011
Dec 03, 2014 12:55 |  #5
It's unlikely that OP would be getting Alienbee - PCB can't be bothered supporting anywhere outside USA (plus there's that weird US voltage business - most of the rest of the world uses 230v). Much depends on ready availability in a prospective purchaser's home country - eg even without the voltage business, by the time Alienbee is imported into Ireland and the 23% VAT is added on (plus the shipping charges too) then they become more expensive than more readily available stuff developed specifically for 230v markets.
Yes, the Bowens mount is the most widely available. But it too is not without it's problems. Firstly, the narrowness of the throat restricts multi-flash applications quite markedly. The other thing stems from the copying/cloning business. If, big BIG 'if', each of the companies who have copied the Bowens mount had actually copied a genuine Bowens mount then much would be OK (setting aside the morality of cloning). Unfortunately, it seems that many have copied other people's copies, inaccuracies have been compounded and they don't all fit! So there are quite a lot of Bowens S-fit look-alikes about to confuse matters.
Just this minute checked with a friend in Dublin who uses Elinchrom - the Eli 'throat' is about 23mm greater diameter than Bowens. So there's more scope for using a couple of speedlights in one modifier if desired. Set against that is the greatly reduced availability of Eli-fit compared with Bowens.
IMO, this side of the Pond I think your choice is simply between those two types. Anything else is going to create more problems than it solves.
I have 3 Photoflex speedrings and 2 of them wouldn't fit my Bowens flash units without surgery. The third one is a beautiful fit.
Last week I received a Lencarta standard bowl reflector/modifier and a Godox standard bowl reflector/modifier (same maker, just different labels). Neither of them will fit my Bowens units at all (too big diameter) though they are lovely and snug on Chinese-made flashes. Conversely, I have a genuine Bowens grid reflector which won't fit the Chinese flash units - the lugs are too fat. They are all described as "Bowens S-fit" and yet for universal application they all require gentle (?) adjustment with a file and a big 'ammer. Absolutely bl**dy infuriating - even for someone well equipped with aforementioned "adjustment devices" :twisted:.
Best idea is to see what O'Leary Cameraworld have in stock (or the very helpful Bermingham's (external link) on Burgh Quay [very near O'Connell Bridge] next time you're in Dublin) and take it from there. There's nothing quite beats laying your hands on the gear!
Phil ǁ Kershaw Soho Reflex: 4¼" Ross Xpres, 6½" Aldis, Super XX/ABC Pyro in 24 DDS, HP3/Meritol Metol in RFH, Johnson 'Scales' brand flash powder. Kodak Duo Six-20/Verichrome Pan. Other odd bits over the decades, simply to get the job done - not merely to polish and brag about cos I'm too mean to buy the polish!
FlickR (external link) ◄► "The Other Yongnuo User Guide v4.12" by Clive Bolton (external link) ◄► UK Railway Photographs 1906-79 (external link)
jaomul
Joined Apr 2011
Dec 03, 2014 15:22 as a reply to  @ Whortleberry's post |  #6
Whortleberry, thank you very much for very informative post. That is great info
1,470 views & 1 like for this thread, 4 members have posted to it and it is followed by 3 members.
What mount question
910 guests, 118 members online
