What all is a favorite / good Wide Angle Lens for use with the 1DX ?
Opinions ?
Thanks !
alexxn Senior Member 396 posts Likes: 9 Joined Nov 2011 Location: S Florida More info | Dec 05, 2014 10:36 | #1 What all is a favorite / good Wide Angle Lens for use with the 1DX ? Nikon D4S, D3, Nikkor AF-S 50 f/1.4G, Nikkor AF-S 85 f/1.8G, Nikon AF-S 24-70mm f/2.8 G ED, Nikkor AF-S 70-200 f/2.8G E VR II
Dec 05, 2014 10:49 | #2 Permanent banHaving just switched my wide angle stuff from apsc to full frame, I am happy with the 17-40 and Rokinon 14mm f/2.8 UMC. Sadly, mine will never see a 1Dx. I use them on a 6D. WARNING: I often dispense advice in fields I know little about!
JohnTrav Member 131 posts Likes: 21 Joined Sep 2013 Location: Philadelphia More info | Dec 05, 2014 11:24 | #3 I use a 17-40L on my 7D and it is fantastic. At f/4 though edges get soft so on a FF I'd expect that to be even softer wider Canon 5D Mark III - Canon 5D Mark II - Canon 7D - Canon 70-200 f/2.8L - Canon 24-70 f/2.8L - Canon 17-40L - Canon 85 f/1.8 - Canon 50 f/1.4 - Canon 580 exii (x2) - rokinon 8mm fishey
Tareq "I am very lazy, a normal consumer" More info | Dec 05, 2014 13:11 | #4 16-35 Galleries:
Voaky999 Goldmember More info | 17-40/f4.0 works fine for me Don
5280Pics Goldmember More info | Dec 05, 2014 19:22 | #6 Tamron 15-30 2.8 Hopefully to be released the first quarter of 2015. _______________
GeoKras1989 Goldmember More info Post edited over 8 years ago by GeoKras1989. | Dec 05, 2014 19:33 | #7 Permanent ban5280Pics wrote in post #17314888 Tamron 15-30 2.8 Hopefully to be released the first quarter of 2015. No offense, but if a 15-30 2.8 would do the job, I'd rather have a 24L II. Two stops more aperture and most likely much better performance at f/2.8. WARNING: I often dispense advice in fields I know little about!
MalVeauX "Looks rough and well used" More info | Dec 06, 2014 01:16 | #8 alexxn wrote in post #17313672 What all is a favorite / good Wide Angle Lens for use with the 1DX ? Opinions ? Thanks ! I think the 16-35 IS pretty much will take all.
Alveric Goldmember More info Post edited over 8 years ago by Alveric. (2 edits in all) | Dec 06, 2014 01:38 | #9 Permanent banZeiss 15mm or Canon TS-E 17mm. If a man can afford the flagship model, he can't justify using a cheap Korean lens with it. 'The success of the second-rate is deplorable in itself; but it is more deplorable in that it very often obscures the genuine masterpiece. If the crowd runs after the false, it must neglect the true.' —Arthur Machen
JMPhotos "Childhood ruined" More info | Dec 06, 2014 01:42 | #10 Rokinon 14mm is a masterpiece of a lens. For the price, everything is perfect! Canon 6D, & Sony α6000
ScottM Goldmember More info | Dec 06, 2014 09:40 | #11 Depends on your budget and needs. Listed from most expensive to least in each category below:
CheshireCat Goldmember 2,303 posts Likes: 407 Joined Oct 2008 Location: *** vanished *** More info | Dec 07, 2014 11:00 | #12 Question is too generic. 1Dx, 5D2 and some lenses
Dec 07, 2014 13:50 | #13 CheshireCat wrote in post #17318289 Question is too generic. If you don't need AF, get a Zeiss prime. The 21 ZE is excellent. OK I'll be more specific, I DO need AF, and also would like to avoid vignetting as well. Nikon D4S, D3, Nikkor AF-S 50 f/1.4G, Nikkor AF-S 85 f/1.8G, Nikon AF-S 24-70mm f/2.8 G ED, Nikkor AF-S 70-200 f/2.8G E VR II
CheshireCat Goldmember 2,303 posts Likes: 407 Joined Oct 2008 Location: *** vanished *** More info | Dec 08, 2014 15:17 | #14 Canon 16-35 f/4 L IS. 1Dx, 5D2 and some lenses
Dec 15, 2014 09:36 | #15 How about the Sigma 10-20 ? Nikon D4S, D3, Nikkor AF-S 50 f/1.4G, Nikkor AF-S 85 f/1.8G, Nikon AF-S 24-70mm f/2.8 G ED, Nikkor AF-S 70-200 f/2.8G E VR II
| Latest registered member is MWCarlsson 1265 guests, 172 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
