Hey everybody,
I've recently started to dabble in flash photography and want to expand from my current on-camera set-up. I've been doing bounce and fill-flash but would like to start getting off camera and eventually adding another flash or two, softboxes, umbrelllas, etc... With Christmas coming up I'm looking into getting some equipment since I've been a good boy this year
My question is, before I start down that rabbit hole which way should I go?
I currently have a Canon 580EXII and was looking at going the PocketWizard route to get it off camera via the Mini TT1, Flex TT5 and AC3 controller (i.e. the expensive route). I'd also probably add another 580EXII or 430EX later on as a secondary flash. I like the idea of being able to utilize ETTL with that method. Although I'm currently reading and watching as much info as I can on flash and lighting so in the future I may just do manual. I'm also thinking of picking up a Sekonic L358 or L478DR as some point also if that makes a difference.
Should I go that route or possibly start looking into the cheaper Yongnuo YN-560II and YN-560TX options? I'd consider myself a serious hobbyist and don't mind spending a little money (I buy mostly used) but I'd like to get the most bang for my buck and the ability to expand the set-up in the future if need be. I currently have no room to set up a studio of any sorts but could probably get enough room to mess around with some portrait shoots if the situation arises. I would also like to be able to use these in outdoor settings as well.
I'd just like to hear other's opinions or experience with either set-up (or totally different set-up for that matter) and do you have regrets for going that route? I just don't know what I don't know and since I'm just starting out with this venture I want to try to avoid the..."I wish I had done this instead..." scenario. Thanks.
