FORUMS General Gear Talk Tripods, Monopods & Other Camera Support
Thread started 06 Dec 2014 (Saturday) 19:38
A screw clamp that gives levers a run for their money
tvphotog
Post edited over 8 years ago by tvphotog. (3 edits in all)
Dec 06, 2014 19:38 |  #1
For all of us who use lever clamp releases, I want to introduce another idea. I recently got a new Markins Qi20 ballhead with the BV-22 gimbal attachment. Both the clamps on the device have the new Markins Quick screw release (external link), which they claim is 3X faster than their old one. I have to tell you that it's correct.
I can open the clamp in one complete turn of the knob, about the same time than it takes to operate the lever release on either my Markins lever clamp or my RRS lever clamp. For me this is a big deal because I can now use any plate or L bracket, and it also gives me security when I carry the sticks on my shoulder with the camera attached. Perhaps not the safest way but the fastest between shots (I always tether the camera to the tripod anyway). Now I have the release speed and the safety.
Image courtesy MarkinsAmerica (external link)
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2014/12/1/LQ_701797.jpg
Image hosted by forum (701797) © tvphotog [SHARE LINK]
Jay
Ireland in Word and Image (external link) Jay Ben Images (external link)5D IV | 5DS/R | Sony RX100 V | 24-105L | 100-400 IIL | 16-35 f/2.8 IIL | 24 T/S f /3.5L II | 17 T/S f/4L | 50mm f/1.2L | 35mm f/1.4L | 70-200 f/2.8L II | 580 EX II | 600 EX-RT | Feisol 3441T/Markins Q3T lever QR | Gitzo 3542L Markins Qi20 BV-22 | Gitzo 5561T RRS MH-02
Samgoit
Dec 06, 2014 19:44 |  #2
Thanks, I didn't realize that was new. I will definitely try one. I don't use the RSS lever clamp due to its incompatibility with so many non-RSS plates, so I'm all Markins all the time.
So what's the best way to get the old clamp off a Markins ball head.
tvphotog
Dec 06, 2014 19:52 |  #3
Samgoit wrote in post #17317094 (external link)
If it were I, I would send it to Steve Yoon at Markins in Canada, unless you're good with a small blow torch to heat the red Loctite that's uses to hold the clamp to the ball. I'm not that steady or mechanically inclined!
Jay
Samgoit
Dec 06, 2014 20:02 |  #4
Yea, I was afraid of that. I've removed quite a few clamps with hex head bolts for mounting hardware, but the Makins is a different animal.
seres
Joined Apr 2013
Dec 06, 2014 20:45 |  #5
Interesting! Fully open in one turn of the knob. Thanks for posting!
—Eric
tvphotog
Dec 06, 2014 22:19 |  #6
seres wrote in post #17317242 (external link)
No, not fully open. Open enough to remove the lens plate or L bracket. Then the reverse to re-secure the L bracket at 90 degrees. Fully open takes more turning, but there's no reason to do that.
Jay
seres
Joined Apr 2013
Dec 06, 2014 23:40 |  #7
Now I understand. But still, opening enough with one turn to remove the plate is a big improvement on most screw clamps. Thanks!
—Eric
sawsedge
Joined Dec 2011
Dec 07, 2014 06:37 |  #8
With the other two fast screw clamps I tried, I didn't feel they closed as securely as my older slow screw knob clamp. How do you feel about the security of the Markins clamp vs older slower designs?
Also, is the bottom designed to fit on a stem with a A-S or RRS boss? I.e. will it work on my Z1?
- John
tvphotog
Dec 07, 2014 08:44 |  #9
sawsedge wrote in post #17317911 (external link)
I'm not sure what you mean about closing "securely", but this Markins closes tightly without movement, as do all the Markins and RRS clamps of any variety which I've had. I don't know about the bottom design and I would email Steve Yoon at www.markinsamerica.com (external link) to ask him.
Jay
blanex1
Joined Nov 2012
Dec 07, 2014 14:50 |  #10
Samgoit wrote in post #17317136 (external link)
its really not that hard to do, use a propane torch with med.flame and put it to the hex nut for about 30 sec.note hear:only to the hex bolt and not the clamp itself,use your elan key to turn and free up the bolt,you must do this while the locktite is at its release point,then set your new clamp on the head,you can use the thread locker to set your new clamp if you like!i have done it and its easy.
canon 7d bg-e7 5d-mk3 1d-mk3 24-105-L 17-40 L 35/1.4 85/1.8 yougnuo 565 ex 580 ex and lots of other canon stuff.canon 70-200 2.8 L
Samgoit
Post edited over 8 years ago by Samgoit.
Dec 07, 2014 19:31 |  #11
blanex1@netzero.com wrote in post #17318711 (external link)
Markins doesn't use a hex bolt that applies from the top like most ball heads.
There's a 3/8 inch stud the entire clamp screws on to. I'm sure it's still DIY possible, but at some point you would have to lock down the ball to remove the clamp. Even with the loctite released I'm not sure how much force I'd need or if using whatever amount of force against the tightened ball might be an issue.
sawsedge
Joined Dec 2011
Dec 07, 2014 19:47 |  #12
tvphotog wrote in post #17318048 (external link)
When I tried the new Kirk clamp, I felt like it would be too easy to loosen the knob accidentally. Like, just brushing it casually could turn the knob.
- John
tvphotog
Dec 07, 2014 19:51 |  #13
sawsedge wrote in post #17319241 (external link)
Not at all with this one. It has a gel feeling when you turn it, you will never accidentally release it.
Jay
sawsedge
Joined Dec 2011
Dec 07, 2014 21:32 |  #14
tvphotog wrote in post #17319251 (external link)
That's excellent.
- John
Charles ­ Brown
Post edited over 8 years ago by Charles Brown. (5 edits in all)
Dec 07, 2014 21:58 |  #15
It would take more than a steep helix screw with a prevailing torque feel to give the RRS lever release clamps a run for their money, imho.
1. The RRS lever release clamp is more reliably repeatable. Where sometimes my hands can't seem to get a firm enough grip to twist a knob tight enough, the leverage of the lever release clamp always snaps the plates down consistently, regardless of my finger strength, the cold weather, or whatever is ailing me that day.
2. The RRS lever release clamp will not over tighten the clamp to the point where it might take pliers to loosen. Just as the power of leverage snaps it tight, the power of leverage releases the plate. With a knob, if I am strong in the morning when I could tighten a knob tightly, but weak in the afternoon when I somehow can't seem to break what I tightened loose, I'm kind of "screwed". With a lever, I can just pry the clamp open.
3. With the RRS lever release clamp, one can always SEE the tightness of the clamp. One cannot see if a screw clamp is tight or not.
All that being said, it is certainly possible to get a screw clamp to hold tighter than a lever release clamp, but the way RRS sets up their belville spring pack in their lever release clamps, I have never felt any thing but a tight, secure, solid connection, even under the lens foots of big glass.
I'm not sponsored by RRS, and have nothing to gain by talking about their product... I'm just addressing the "levers a run for their money" post title, and listing 3 reasons why I think this attractive looking Markins clamp has further to run.
For example, how useful is the bubble level nested in the valley of the Markins if you can't even see it with a lens or camera mounted? The bubble level on the RRS lever release clamp is OUTSIDE the clamp zone, on the shoulder of the clamp, so it can be seen with the gear mounted.
There's a bit more distance to run there before catching up.
6,508 views & 1 like for this thread, 9 members have posted to it and it is followed by 3 members.
1014 guests, 107 members online
