going from tungsten to daylight is going cooler, not warmer
and as said, as long as you don't have mixed lighting, you'll be fine with color balance.
as long as you stick with real Kino tubes you should be fine with color rendition too, i think all of their bulbs are 95 or higher CRI. Yes you are missing a small part of the spectrum so for the absolute most demanding applications you might consider a different source, but it would be a rare case that you didn't get an acceptable image.
