I just purchased a gripped Elan 7 and a Sunpak 5000AF Flash. The Sunpak seems to work fine on the Elan 7, in either auto (which I prefer) or TTL.
Question number 1 is: Will it just be easier to use one of my EX-series flashes with the Elan 7? I know if I bounce with the Sunpak, I have to accomodate that by opening the aperture on camera from what is entered in the flash. Won't the EX account for the bounce just like it does on my EOS 60D/6D?
Question number 2 is: Are TTL and ETTL different enough that I can't use the Sunpak on my digital cameras? I mounted it, but the settings are all funky. I have to dismount to change ISO. Even shutting off the camera doesn't work.
Question number 3 is: The Sunpak is capable of acting as a slave. Is that just for firing, or will it adjust output as directed by my 580EX II master? If it is just a dumb 'fire-now' slave, I can use it for background group C, if I set output manually.
I can answer question 3 by setting up a studio session and seeing what happens. The other two questions require wasting some film. I was hoping someone could help me out so I can avoid having to do that.
