Thread started 24 Dec 2014 (Wednesday) 17:35
Old Manual Lens - Exposure question
red ­ snapper
Gallery: 104 photos
Dec 24, 2014 17:35 |  #1
Hey all,
Merry Christmas and all that.
I have been playing around with my Petri 50mm 1.7 and have noticed and interesting phenomenon. I use Av mode and set the aperture manually. I have always had to set exposure compensation to under expose by around 2 stops with this lens. I was using Live View with this lens this morning and noticed that it was correctly exposing. Has anyone else experienced this and can someone explain what is happening. I can work with it but am just curious.
Cheers
Tim
If you do what you always do, you get what you always get.
7D, 400D, Sigma 30 f1.4, Sigma 17-70 f2.8-4.5, Canon 70-200 f4L (non IS), Canon 10-18mm f4.5-5.6 STM, Petri 50mm f1.7, Revuenon-Special 35mm f2.8, Revuenon-Special 135mm f2.8, 430 EX II,
flickr (external link), 500px (external link)
killwilly
Gallery: 21 photos
Dec 25, 2014 02:46 |  #2
Hi Tim.
I have been using manual lenses for many years and have never found a difference between LV and normal use. However, I did find I had to under expose by about 2 stops on my 450D, which I don't have to do on my 7D, or EOS-M.
Perhaps someone will be along and explain why you are experiencing this issue. :-)
Alan. flickr (external link)
Canon 7D. Canon 15-85 EF-S Lens. Canon 55-250 EF-S Lens. Speedlite 430ex 11.
Canon EOS-M. Canon 18-55 EF-M Lens. Speedlite 90EX.
Sigma APO 150-500mm F5-6.3 DG OS HSM.
melcat
Joined Nov 2010
Dec 25, 2014 03:18 |  #3
When you shoot in Live View, the sensor is seeing what it's seeing and exposure is measured from that, so it always has to be correct.
When you don't use Live View, the exposure reading is taken from a meter in the top of the camera looking through the focussing screen. That focussing screen lights up differently depending on the aperture of the lens. The firmware knows that, and with a Canon EF lens adusts the reading to adjust for the difference. But with an adapted lens, it doesn't know the lens's aperture (or what lens it is), so can't make the adjustment.
Some Canon cameras can be fitted with an -S type screen that isn't affected much at all by the lens's aperture, at least for an f/1.7 lens like yours. Since there's little to no adjustment required, the firmware doesn't need to know the lens's aperture and type, and the reading will be correct. At least, I found that to be so with the particular adapted (OM) lenses I used to use on my 5D.
829 views & 0 likes for this thread, 3 members have posted to it and it is followed by 2 members.
1582 guests, 138 members online
