Thread started 27 Dec 2014 (Saturday) 09:13
problem with CTR-301P Trigger/Transmitter
the.forumer
Joined Oct 2011
Post edited over 8 years ago by the.forumer.
Dec 27, 2014 09:13 |  #1
I bought these cheap Yongnuo triggers a couple years back with my 460s and it worked flawlessly in a 3 flash setup. My strobist interest died down for a couple years and was revived recently. When using it with my 580ex2 x1, there seems to be a problem - the flash is triggered only half the time. I have changed all the batteries - the flash, transmitter and receiver but to no avail. It is also most certainly not because the flash is recycling. the transmitter is also working well - every press on the transmitter triggers the flash 10 out of 10 times.
Is there anything else I should try before deciding it should become a paper weight? I probably popped less than 300 times using the set of Tx/Rx.
Thanks!
VicHelis
Post edited over 8 years ago by VicHelis.
Dec 27, 2014 13:08 |  #2
Hi!
Hope this helps:
How to modify CTR-301P photo flash triggers for low voltage strobes (external link)
modding yongnuo ctr-301 flash trigger for 420ez speedlite (external link)
Trailboy
Dec 28, 2014 02:34 |  #3
Make it a paper weight.
Trigger tech has progressed rapidly over the last few years, and your choices are vastly superior to your 301s.
the.forumer
Joined Oct 2011
Dec 28, 2014 19:57 as a reply to  @ Trailboy's post |  #4
I have seen the latest releases, but the biggest downside so far is the size and weight of the transmitters and receivers. Is there any new trigger that can match the size of my CTR301p while maintaining 10/10 shot triggering?
thanks.
the.forumer
Joined Oct 2011
Dec 28, 2014 19:57 as a reply to  @ VicHelis's post |  #5
is there a need to mod my trigger, since I am only using it with my 580s/460s?
VicHelis
Dec 29, 2014 06:39 as a reply to  @ the.forumer's post |  #6
Decide for yourself, but described trigger mod is simple and suitable also for your flashes.
Trailboy
Post edited over 8 years ago by Trailboy. (2 edits in all)
Dec 29, 2014 07:15 as a reply to  @ the.forumer's post |  #7
Rf 602/603.
If you're a tinkerer, have the time and are attached to your 301s, then go for it.
Personally, I can't believe anybody would want to go back five years to the dark days of crappy triggers on the wrong frequencies that needed aerial mods to get the little sh!ts to work slightly better.
I have a pile of pt04s if you have too much hair at present...
VicHelis
Dec 29, 2014 08:26 as a reply to  @ Trailboy's post |  #8
+1 :) however CTR-301P is sufficient for the tasks of the TS
1,693 views & 0 likes for this thread, 3 members have posted to it.
1501 guests, 134 members online
