I have a 580EX II and a Canon T2i. For Christmas I got a set of Yongnuo wireless triggers. I was using this setup today for the first time trying to get some bird shots on a gloomy day. I realize that ETTL doesn't work using this trigger. Being a slight novice with this flash it was still in ETTL mode and I simply turned the power down to -2 which seemed to be the right amount of light after a couple test shots.
I took a few more shots of some birds, easily a couple minutes apart when I noticed an odor. I finally realized it was coming from the 580EX II. The lens is smoked just a bit as you can see by the picture below.
What have I done wrong or is my flash simply dying again?
Note that the flash does work. My suspicion is that leaving in ETTL mode was my error.
