Thread started 30 Dec 2014 (Tuesday) 17:52
Light stand?
jeljohns
Dec 30, 2014 17:52 |  #1
I have an Impact stand, 10 ft I think. I also have a 32" Impact umbrella. The stand toples over outside every time! Even when there is no wind. Now the umbrella is all bent. I want to get a 60" umbrella. Which stand will be strong enough to hold it?
kaitlyn2004
Dec 30, 2014 23:06 |  #2
Modifiers are like sails with any amount of wind. Were you weighing your stand down (i.e. sandbags on the legs)?
My Landscape Photography Videos (external link)
My Instagram (external link)
Whortleberry
Joined Dec 2011
Dec 31, 2014 06:07 |  #3
Even without considering the basic laws of levers established well over 2000 years ago, I'm wondering quite why you would even expect your lightstand to remain upright when it's inherently destabilised by the offset of the umbrella? As Kaitlyn mentions, use a sandbag or two - but place them for maximum effectiveness. Mechanical advantage (or disadvantage, to be pedantic) requires that the sandbag(s) be considerably heavier than you would perhaps anticipate because of their necessary placement so close to the centre of gravity.
An alternative would be to use guy-ropes where practicable.
Phil ǁ Kershaw Soho Reflex: 4¼" Ross Xpres, 6½" Aldis, Super XX/ABC Pyro in 24 DDS, HP3/Meritol Metol in RFH, Johnson 'Scales' brand flash powder. Kodak Duo Six-20/Verichrome Pan. Other odd bits over the decades, simply to get the job done - not merely to polish and brag about cos I'm too mean to buy the polish!
FlickR (external link) ◄► "The Other Yongnuo User Guide v4.12" by Clive Bolton (external link) ◄► UK Railway Photographs 1906-79 (external link)
gonzogolf
dumb remark memorialized
Gallery: 38 photos
Dec 31, 2014 06:26 |  #4
Its not the stand strength. At worst it might be the width of the base, but it's the wind tipping your umbrella and stand. Sandbags help as does using an umbrella softboxes that catches less wind. These have the added benefit of being cheap enough that you don't mind dinging them up occasionally. http://www.amazon.com …keywords=umbrel​la+softbox (external link)
jeljohns
Jan 01, 2015 09:59 |  #5
Honestly, I was watching some videos on off camera lighting. I wanted to try a technique just shown in the video so I paused the video and went outside quick. In the video they did not use sandbags. In the back of my mind I thought about that, but didn't have a sandbag.
What kind of sandbag can be used on the stands? Do you guys make your own or buy them?
tandemhearts
Joined Mar 2014
Jan 01, 2015 10:03 |  #6
jeljohns wrote in post #17360383 (external link)
http://smile.amazon.co​m …DUTY-SADDLE/dp/B00551636O (external link)
Fill them with pea gravel from the local home improvement store, not sand.
gonzogolf
Gallery: 38 photos
Jan 01, 2015 10:06 as a reply to  @ jeljohns's post |  #7
I use weights rather tha sand bags. I have a collection of ankle weights, plate steel weights from a weight bench, and occasionally use a gallon milk jug gilled with water depending on if I having to carry it far and water is available nearby.
Alveric
Gallery: 38 photos
Jan 01, 2015 13:24 |  #8
That stand is poor quality to begin with. I'm willing to bet that it's quite light, innit? If so, it has poor structural strength. Even with sandbags, the stress on the upper part (wind, or heavy lights/light formers, or —Heaven forbid!— a boom or grip arm) will bend it. Been there myself with such stands. Another 'feature' is that their legs are shorter, which makes them even more unstable.
I'd get another stand, like a Manfrotto 1052BAC.
gonzogolf
Gallery: 38 photos
Jan 01, 2015 13:32 as a reply to  @ Alveric's post |  #9
Ive got an impact 10ft stand thats as solid as any manfrotto of an equivalent size.
Alveric
Gallery: 38 photos
Post edited over 4 years ago by Alveric. (2 edits in all)
Jan 01, 2015 15:22 |  #10
I've got a Westcott lightstand that is very portable (folds shorter than others and has a smaller footprint) that bent when I attached a grip arm holding a reflector to it. If the Impact stand is of similar quality... well. I've also got an Impact umbrella bracket that's total junk. I'm not buying B&H's own brand products again.
One thing, regardless of brand, though: the more sections a stand has, the less structural strength it has and the easier it'll bend.
Carpe ­ Lux
Jan 02, 2015 00:58 |  #11
Try replicating the stand-umbrella setup indoors first...same height, same leg spread. Then push on it from different directions to see just how stable it is in these windless conditions. Then start laying on the weight...bags, jugs of water, weights....all those are great suggestions. Test some more.
Once you've dialed in the support, try it outside. But never more than a breeze, these setups are inherently unstable....if it's windy then you need a VAL (voice activated lightstand=a friend to hold the stand/umbrella.)
P.S. I suppose you could also try stakes over the legs or tie-downs to save weight, but = more hassle & time.
RicoTudor
Joined Jul 2014
Jan 02, 2015 01:26 |  #12
Tying your stand to the ground is a guy thing.
Canon, Nikon, Contax, Leica, Sony, Profoto.
Left ­ Handed ­ Brisket
Gallery: 15 photos
Joined Jun 2011
Jan 02, 2015 06:50 |  #13
RicoTudor wrote in post #17361645 (external link)
:lol:
Wilt
Jan 02, 2015 10:20 |  #14
gonzogolf wrote in post #17358700 (external link)
Base circle diameter of the legs is insufficiently large to overcome the weight (umbrella/ribs) at the end of a lever arm (the umbrella shaft) even with zero wind.
3,025 views & 0 likes for this thread
Light stand?
Latest registered member is majorsite2
1001 guests, 230 members online
