Thread started 02 Jan 2015 (Friday) 18:16
Off to Chile
picworx
Joined Jun 2005
Post edited over 8 years ago by picworx. (3 edits in all)
Jan 02, 2015 18:16 |  #1
I am off to Chile to the Atacama Desert and would appreciate it if I could get some settings for photography at night. I want to do time lapse of the heavens so this is what I think is needed, please correct me if I am wrong here? I will also try some star trails as well.
TIME LAPSE
Manual mode
wides lens mine is 17-40 set to f4
set lens at infinity
manual focus - where do I focus?
speed 1/30th - tripod
iso 3200
shooting interval every 30 seconds using intervolometer
noise reduction on for long exposure
now for
STAR TRAILS
same as above except set for 30" second exposure - duration ?
Cheers
The Print is What Really Matters
Desertraptor
Gallery: 212 photos
Jan 02, 2015 18:55 |  #2
There's a great app called Magic Lantern for Canon cameras. Has many cool options including and intervalometer and long exposure (via bulb mode) over 30 secs.
Infinity is your focus? Pick a star you can focus on through the viewfinder or liveview and set to manual.
I'd go far slower for time lapse. You can get 30 sec exp with no trails and you'll get far more detail.
Star trails Exposure for as long as you can without blowing the sky.
I'd suggest practicing before you go at home
Peter
Canon 6D|60D|40D
Lens 10-22mm f2.8|50mm f 1.8|100mm f2.8 Macro
24-70mm f2.8|L100-400mm f4.5-5.6L
Flash 430EX II
Telescope Skywatcher 600mm ED80 f7.5 GEM EQ3
the ­ jimmy
Jan 02, 2015 19:43 |  #3
picworx wrote in post #17362850 (external link)
TIME LAPSE
Manual mode
iso 3200
now for
STAR TRAILS
Cheers
noise reduction OFF for long exposure..1/30th isn't a long exposure, and even doing astro photography this is best turned off.
picworx
Joined Jun 2005
Jan 03, 2015 18:16 as a reply to  @ Desertraptor's post |  #4
Isn't magic lantern another firmware for the camera?
picworx
Joined Jun 2005
Jan 03, 2015 18:21 as a reply to  @ the jimmy's post |  #5
I thought nr for long exposure was the option that should be on? perhaps you can explain this?
Desertraptor
Gallery: 212 photos
Jan 03, 2015 22:49 |  #6
picworx wrote in post #17364507 (external link)
It sits ontop of the Canon firmware. Does not replace it. It just gives functionality Canon should have or could have included.
I use it for my DSO images
Peter
Canon 6D|60D|40D
Flash 430EX II
Celestron
Jan 03, 2015 23:06 |  #7
picworx wrote in post #17364518 (external link)
Short exposures with NR off will produce a lot of Noise in your image but the longer the exposure and the more you stack will reduce a lot of the noise to start with . So if you have NR on for long exposures your images in the log run will be even more softer than you want or need to make a good image .
the ­ jimmy
Jan 04, 2015 08:05 |  #8
The bottom line is noise can be dealt with better in post processing, also consider, if you're doing an astro time lapse or tracking on a mount you'll have twice the in camera processing time
otherwise required
1,790 views & 0 likes for this thread, 4 members have posted to it.
Off to Chile
1510 guests, 132 members online
