Thought I would post up a few shots I did and try and get some feedback from the ETTR experts out there in terms of Canon and Blinking Highlights and the amount of available room to still pull back details.
I began shooting weddings last year and basically adopted the approach of metering and setting the exposure based on the 'white' dress such that the exposure was generally as high as possible (assuming someone had a dark suit on) without the dress Blinking with highlight alerts ON - i.e. exposing to the right (ETTR) without getting into trouble - and I have been generally very happy that I was able to do whatever I needed to in post without getting into trouble - I don't think I will change this but since the camera (5D3) does NOT have a RAW meter, and we do not know exactly how much safety canon has built into the meter, I thought I would run an experiment, post up the pictures, and see if anyone has developed any rules-of-thumb that might dictate how much into the Blinking Zone we can go and still be able to recover the Blinking Highlights
What I did was hang a white wedding dress in a window, place camera on tripod (35mm L), first meter using Evaluative Metering - take picture, then use Spot Metering - take picture (spot was 1/3rd of a stop more light), and then jumped forward 1 full stop more light when I started seeing Blinking (ON THE DRESS). Even with the initial Evaluative Metering there was blinking in the top right corner window - so Blinking showed up on the dress +1 1/3 stops more light on Evaluative and 1 Full Stop above Spot (but still this blinking was really the light shining through the dress).
What I then did in Lightroom was adjust Highlights down as required, then moved to Whites down in addition as required and then Exposure down in addition as required so that I had NO Blinking Highlights - I also, starting when the dress started blinking, increased the Shadows by +97 in every picture to bring life to the bottom of the dress but more importantly to analyze the Black Calculator and Book that was sitting in the Window to see if there was more detail / less noise by using ETTR - I should have put a much bigger black thingy there to replicate a Black Suit but live and learn - on this issue there was some improvement for sure but not as much as I was maybe hoping for - and thus, to jump to the answer, I think you have to be careful when you are using ETTR once you get into the land of the Blinking Highlights as there isn't that much to be gained but there is some for sure.
SOOC with Evaluative Metering (but Highlights reduced -13 to remove Blinking Highlights in top left window - iso 100, f2, 1/200)
SOOC with Spot Metering (but Highlights reduced -15 to remove Blinking Highlights from window - iso 100, f2, 1/160)
IMAGE LINK: https://flic.kr/p/qsxQxS
(iso 100, f2, 1/80, Highlights -56, shadows +97 - this is a full stop more light than Spot Metering and the Dress started to Blink)
IMAGE LINK: https://flic.kr/p/qsEkoK
(iso 100, f2, 1/50, highlights -62, shadows +97, +1 1/3 above Spot)
IMAGE LINK: https://flic.kr/p/qsEkdp
(iso 100, f2, 1/30, highlights -84, shadows +97, +1 2/3 above Spot)
IMAGE LINK: https://flic.kr/p/pNkgWp
(iso 125, f2, 1/30, highlights -100, shadows +97, +2 Stops above Spot)
IMAGE LINK: https://flic.kr/p/qK312m
(iso 160, f2, 1/30, highlights -100, whites - 54, shadows +97, +2 1/3 above Spot)
IMAGE LINK: https://flic.kr/p/qsEjBV
(iso 200, f2, 1/30, highlights -100, whites - 100, shadows +97, +2 2/3 above Spot)
IMAGE LINK: https://flic.kr/p/qK2ZGo
(iso 250, f2, 1/30, highlights -100, whites - 100, Exposure -0.60, shadows +97, +3 Stops (in camera) above Spot)
IMAGE: https://farm8.staticflickr.com/7483/16238537491_fc9564a532_b.jpg
I also went to ISOs 320 and 400 and both required Lightroom Exposure reductions - but I was still able to avoiding Blinking Highlights - but there is clearly data loss happening.
Anyways, that is what I did and the result is I think I may feel comfortable exposing a little further to the right than I have in the past - and I think I feel pretty safe to say that if you need the shadow details, I think you can Expose at least 1 full stop (maybe 1 1/3) into the realm of the Blinking and feel pretty confident that you can get it back in post.
Please let me know your thoughts
Paul
