nqjudo wrote in post #17377540
There are some vintage lenses that are of very high quality and others worth seeking out if you really appreciate nice bokeh. Some lenses (the Helios 44-2 comes to mind) can create 'swirling' bokeh. Some vintage lenses have an absolutely outstanding smooth, creamy like bokeh. I am not sure if the theory is correct but vintage apertures were constructed using more blades than modern lenses. This made the aperture more smooth and circular thus creating smooth, circular bokeh. I used to have a dozen or so vintage lenses that I mounted on the 5D via an adapter. Lots of great bokeh but I found focusing difficult. That would probably be much easier now with live view, focus peaking and such. I found the vintage lenses sometimes gave a less contrasty image often with poor colours but PP fixed that up well.
It really depends on what you get, the extra blades aren't what caused the swirly bokeh though, that was a result of the shape of the elements used I believe. For instance, even my Helios 44-4 which only has 6 aperture blades shares the same swirly bokeh characteristics of the earlier 44-2.
As for the contrast, I actually prefer lower contrast lenses since they give you more to work with in post production than a higher contrast lens does, but most of my vintage lenses are just as high contrast as a modern equivalent and I often prefer the colors from them as well... as I said earlier, the vintage matters far less than the lens itself, there are fantastic lenses from the 40's, 60's, 80's, 2010's and everywhere in-between, it's just a matter of what you get
The biggest improvements have come from he coatings, more modern lenses (90's onward) definitely are less prone to flaring, but in my experience that's the biggest difference if we're talking prime lenses. Modern zooms in my experience are significantly better than vintage ones though for the most part.
And focusing can be done easily with a DSLR if you get a precision manual focusing screen. I had the EG-S screen in my 6D and focusing with it was just as easy if not easier than focusing via focus peaking with my a7R
I actually miss my OVF a little bit for MF, but I think that's mostly because I'm still not used to using an EVF.
