In ACR you can select files then press [control]-[L] to start the slide show.
After viewing, you press [escape] to exit.
However, when you exit, all files selected before starting the slideshow are no longer selected - just the file you were viewing when [esc] was pressed.
Is there a way to exit slideshow with the same files selected as were selected when you went in?
