I'm very comfortable with watermarks in LR5. However, I need more flexibility in where I can place a small text watermark. Is there a way to place it in an area of the image that isn't one of the 9 anchors, or inset adjustments.
Jan 14, 2015 20:40 | #1 I'm very comfortable with watermarks in LR5. However, I need more flexibility in where I can place a small text watermark. Is there a way to place it in an area of the image that isn't one of the 9 anchors, or inset adjustments. _______________
Jan 14, 2015 21:15 | #3 PineBomb wrote in post #17382972 Between the inset function and the 9 fields, can't you put the watermark anywhere you want? What are you trying to do? No I can't. The watermark is small on purpose. The 9 anchors aren't always in convenient locations and the insets only allow for slight horizontal and vertical movement. I want to place the mark in an inconsoicuous place in the image and that will vary from image to image. Just trying to learn if that's possible with LR5. _______________
Nogo POTN record for # of posts during "Permanent Ban" 9,193 posts Gallery: 17 photos Likes: 685 Joined Dec 2013 Location: All Along the Natchez Trace (Clinton, MS) More info | Jan 14, 2015 21:16 | #4 PineBomb wrote in post #17382972 Between the inset function and the 9 fields, can't you put the watermark anywhere you want? What are you trying to do? There are limitations. The corners let you move horizontally and vertically. The other points are limited. If you can't get the text to where you want it using the horizontal and vertical sliders, about all you can do is enter blank spaces to move the text. To put it lower, you can enter lines by entering a space, then hitting Enter to get a blank line. Philip
Jan 14, 2015 21:20 | #5 Nogo wrote in post #17383014 Other than that, the only way to position it even more precisely would be by making a transparent PNG with the text where you want it. Of course if you do that, it is probably as easy to just just the editor you made the PNG with to add the watermark. OK, that's an idea. what type of software would be needed to make such a transparent overlay. _______________
Nogo POTN record for # of posts during "Permanent Ban" 9,193 posts Gallery: 17 photos Likes: 685 Joined Dec 2013 Location: All Along the Natchez Trace (Clinton, MS) More info | Jan 14, 2015 21:33 | #6 Larry Johnson wrote in post #17383021 OK, that's an idea. what type of software would be needed to make such a transparent overlay. Most any full editor. Of course Photoshop or Photoshop Elements will, but so will many of the less expensive ones. Philip
Nogo POTN record for # of posts during "Permanent Ban" 9,193 posts Gallery: 17 photos Likes: 685 Joined Dec 2013 Location: All Along the Natchez Trace (Clinton, MS) More info | Jan 14, 2015 21:46 | #7 Just looking around quickly I see that Pixlr Philip
DanMarchant Do people actually believe in the Title Fairy? 5,635 posts Gallery: 19 photos Likes: 2058 Joined Oct 2011 Location: Where I'm from is unimportant, it's where I'm going that counts. More info | Jan 14, 2015 23:14 | #8 You can't get 100% freedom to place anywhere using the text watermark but you can alter the position quite a bit by adding blank lines. Dan Marchant
Thanks all. _______________
birderman Goldmember 1,052 posts Likes: 44 Joined Mar 2011 Location: London, UK More info | Jan 15, 2015 07:39 | #10 what about mogrify ? Only issue I think you may have with using LR or Mogrify to place watermarks is that the watermark is added during the export/print operation and applies the same settings to the group/collection of images being printed. If you require each image to have the watermark in different position or size then it may be quicker to export all the images then apply watermarks to each using third party program or Photoshop. Doing a google there appears to be quite a number of third part shareware programs for batch watermarking. Birderman
| Latest registered member is semonsters 1689 guests, 140 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
