Jan 15, 2015 08:31 | #2 Thank-you! This is one of the first non-Canon lenses I'm taking a look at. 2x 7D Mark II | 70D | 5DSr
Image hosted by forum (707939) © Leigh [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Interesting comparison to Tamron. Though the Tamron "takes a hit" at 6.3; they're both pretty close by F8. Leigh
Jan 15, 2015 10:10 | #4 kinda disappointing, @600, looks like the difference is fairly negligible compared to the tamron 150-600 Sony A7siii/A7iv/ZV-1 - FE 24/1.4 - SY 24/2.8 - FE 35/2.8 - FE 50/1.8 - FE 85/1.8 - F 600/5.6 - CZ 100-300 - Tamron 17-28/2.8 - 28-75/2.8 - 28-200 RXD
ceriltheblade Goldmember 2,484 posts Likes: 4 Joined Mar 2007 Location: middle east More info | Jan 15, 2015 11:17 | #5 also too bad that they couldn't add to the comparison the 100-400 II with and without TC. 7D/5dIII
DanC.Licks Member 229 posts Likes: 67 Joined Aug 2009 Location: Mauerbach, Austria More info Post edited over 8 years ago by DanC.Licks. | Jan 15, 2015 11:59 | #6 Look at 300mm. Much bigger difference wide open. At 8 seems about the same..
ptcanon3ti Cream of the Crop More info | Jan 15, 2015 12:08 | #7 I'm just wondering if the Sigma Sport is worth $1000 more than the Tamron? I know the Sigma is built like a tank and has vast weather sealing...but still.... Paul
DanC.Licks Member 229 posts Likes: 67 Joined Aug 2009 Location: Mauerbach, Austria More info | Jan 15, 2015 12:22 | #8 I wouldn't say it is twice as good for twice the price, but that is not the way it works. Hard to quantify such things.
hoodlum Member 142 posts Likes: 8 Joined Aug 2013 Location: Markham, ON Canada More info | Jan 15, 2015 12:52 | #9 There is not a lot of room for the IQ from the Sigma Contemporary lens to drop below the Sport without dropping below the Tamron as well.
Jan 15, 2015 13:15 | #10 hoodlum wrote in post #17383957 There is not a lot of room for the IQ from the Sigma Contemporary lens to drop below the Sport without dropping below the Tamron as well. Most people buy these lenses for the long end and the only thing you loose with the Tamron over the sport is lower edge sharpness when wide open. Otherwise they are equal for sharpness. and even then, it's not quite straight forward. wide open @600, the tamron has better center and weighted average. @f8, sigma has better center, but tamron has better weighted average. @ F11, again, tamron is better. Sony A7siii/A7iv/ZV-1 - FE 24/1.4 - SY 24/2.8 - FE 35/2.8 - FE 50/1.8 - FE 85/1.8 - F 600/5.6 - CZ 100-300 - Tamron 17-28/2.8 - 28-75/2.8 - 28-200 RXD
Philihase Member More info Post edited over 8 years ago by Philihase. | Jan 15, 2015 14:30 | #11 Strange that the negative point mentioned is lens creep downwards especially as the reviewer says, quote, https://www.facebook.com …e-Photos-852961268075109/
artyman Sleepless in Hampshire More info | Jan 15, 2015 17:49 | #12 It isn't all about sharpness though obviously it should at least match or better the Tamron, but is there a difference in AF performance, that justifies the addition cost of the Sigma. If AF performance is equal it would on the face of it be difficult to justify the higher cost. Art that takes you there. http://www.artyman.co.uk
BigAl007 Cream of the Crop 8,120 posts Gallery: 556 photos Best ofs: 1 Likes: 1682 Joined Dec 2010 Location: Repps cum Bastwick, Gt Yarmouth, Norfolk, UK. More info | Jan 15, 2015 18:01 | #13 The other big advantage from my point of view for the Sigma is the two mode OS. The Tamron VC will not work while panning at slow shutter speeds. This is important when the majority of the time one is trying to shoot passing through an angle of 180 degrees at shutter speeds of 1/160 or slower. You would get better results with the VC off on the Tamron, but I still think you would be down under 30% success rate with the Tamron. At least here in the UK the Sigma Sport is only about 60% more expensive than the Tamron, not the 100% it seems to be in the USA.
Jan 15, 2015 19:39 | #14 artyman wrote in post #17384373 It isn't all about sharpness though obviously it should at least match or better the Tamron, but is there a difference in AF performance, that justifies the addition cost of the Sigma. If AF performance is equal it would on the face of it be difficult to justify the higher cost. The AF of the sigma better be spectacular because the tamron is pretty good, certainly good enough for me. BigAl007 wrote in post #17384396 The other big advantage from my point of view for the Sigma is the two mode OS. The Tamron VC will not work while panning at slow shutter speeds. This is important when the majority of the time one is trying to shoot passing through an angle of 180 degrees at shutter speeds of 1/160 or slower. You would get better results with the VC off on the Tamron, but I still think you would be down under 30% success rate with the Tamron. At least here in the UK the Sigma Sport is only about 60% more expensive than the Tamron, not the 100% it seems to be in the USA. Alan this is a bigger issue than the AF issue IMO. I didnt shoot many pans while I had the lens, however, I can see this being a big annoyance if you do it a lot. Sony A7siii/A7iv/ZV-1 - FE 24/1.4 - SY 24/2.8 - FE 35/2.8 - FE 50/1.8 - FE 85/1.8 - F 600/5.6 - CZ 100-300 - Tamron 17-28/2.8 - 28-75/2.8 - 28-200 RXD
DanC.Licks Member 229 posts Likes: 67 Joined Aug 2009 Location: Mauerbach, Austria More info | Jan 16, 2015 05:33 | #15 I talked with a couple of guys with the Tamron 150-600, and they said essentially what Alan said. They both just leave the VC turned off all together as they felt they were getting sharper pictures without it. The Sigma IS system seems to be better, and that alone would be a deal breaker for many.
| Latest registered member is semonsters 1457 guests, 129 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
