Thread started 15 Jan 2015 (Thursday) 09:15
Communication with Lens?
fish ­ dog
Joined Jan 2014
Jan 15, 2015 09:15 |  #1
I have a Canon ESO Rebel T3 and while using my Tokina 12-24 lens yesterday I started getting an error message that the camera was "having trouble communicating with the lens, clean contacts" (Probably not an exact quote of what it said but I'm sure, if you've had the problem you know what I mean). I was out in the middle of nowhere with minimal equipment so I just took the lens off and rubbed my finger over the contacts and it worked for couple more shots then back to the error message. Did this a couple more times then it seemed that rubbing the contacts with my finger wasn't going to help any more. Question is what is the proper way to clean the contacts so this doesn't happen again? Is it likely the lens or camera (no, I didn't try another lens yesterday)? Is this something I should take to canon to get fixed or something I can do myself? Thanks in advance.:-)
troutfisher
Gallery: 23 photos
Jan 15, 2015 09:34 |  #2
Try cleaning the contacts with a pencil eraser , we would call it a rubber in the UK but I think that has a different connotation in the US
Chris
" Age and treachery will always defeat youth and enthusiasm"
scotchtape
Joined Aug 2013
Jan 15, 2015 11:05 |  #3
I thought standard response was a bit of rubbing alcohol and a clean cloth...
JWdlft
Joined Feb 2013
Jan 15, 2015 11:26 |  #4
troutfisher wrote in post #17383682 (external link)
Many sources say do not clean contacts with an eraser, so as not to damage thin gold plating. As scotchtape says, a clean cloth and rubbing alcohol should do the job.
tma-888
Joined Dec 2014
Jan 15, 2015 11:36 |  #5
I use Deoxit to clean electronics contacts.
For "delicate" ones with gold contacts, I use the Deoxit Gold.
For the lens contacts, I would spray a little bit on a cotton bud
and clean the contacts with it.
Warning: DO NOT SPRAY DIRECTLY TO LENS CONTACTS.
Cheers.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/01/3/LQ_707950.jpg
Image hosted by forum (707950) © tma-888 [SHARE LINK]
Frodge
Joined Nov 2012
Jan 16, 2015 14:40 |  #6
Ribbon is probably broken. Is that the first or second version of the lens...,
“It's kind of fun to do the impossible.” - Walt Disney.
Equipment: Tokina 12-24mm, Canon 40mm 2.8, Tamron 17-50 2.8 XR Di, Canon 18-55mm, Canon 50mm 1.8, Tamron 70-300VC / T3I and 60D
John ­ from ­ PA
Joined May 2003
Jan 16, 2015 16:05 |  #7
tma-888 wrote in post #17383833 (external link)
Cheers.
If alcohol doesn't work don't use the Deoxit. At $15 it doesn't offer much benefit if any over alcohol.
1,681 views & 0 likes for this thread, 7 members have posted to it.
1498 guests, 127 members online
