GeoKras1989 wrote in post #17384551
I just shot an evening of comparison shots between my Σ70-200 f/2.8 OS HSM, which I've had for years, and the 70-200 f/4 USM I got today. Both wide open, the Canon is much sharper. There is very little IQ difference with both at f/4, at any focal length. The Canon is faster to focus and is
1/2 the weight, which is why I bought it. About 96% of my 70-200 library is at 1/200 or faster. Most of my 70-200 work on the 6D is flash or outdoor kids' stuff. All of my 70-200 stuff on the 60D is larger field outdoor stuff.
One thing that was apparent in the direct comparison: If the Canon really is 70-200, the Sigma is probably 65-175. The difference at the long end is easily noticed. After I saw it, I compared the wide end. Not as pronounced, but certainly there.
I know I'll get more use out of the smaller, lighter Canon. I'm thinking I should just sell the Sigma, but I hate to regret selling things (135L and my XSi kit come to mind) a few months down the road. Are there any good reasons to hold onto the Sigma 70-200?
Heya,
I see no reason to keep the Sigma 70-200 OS. The fact that you bought a slower aperture Canon version tells you everything you need to know about whether you care about F2.8 or not.
But that said, you tried the non-IS version and shot at fast shutter speeds, not sure IS will help that truly? I think you will find it does the same thing. IS helps for panning and motion blur (from you) at low shutter speeds only. At 1/500s+ you're not going to get a real benefit other than mental. But, that said, I shoot with VC (same thing) on even with 1/2000s shutter on my 600mm lens. The reason for me is not for the motion blur, since it's that fast, but because it stabilizes the view finder so I can more easily keep my target on the cross hair. So it does have benefits even at high shutter speeds, but really, it's biggest benefit is the slower shutter speed. Regardless, try out the F4L IS, it's an excellent lens.
The F4L IS however is optically superior to the non-IS, and still very light. If you can swing it, go for it. It's better than the F2.8 version wide open (only the MKII tops it).
If you find you need a 200mm F2.8 lens, without the weight, look to the old MK1 prime, or the new MKII prime (same optically). Light weight, sharp wide open, really good bokeh.
Very best,
