Tommorow will be buying slighly used 7D Mark II.
1. Which program, can tell me it's shutter count?
2. There is infamous > 100 pages 7D Mark II AF issues thread, so what I should check before buying it?
Shift7 Member 90 posts Likes: 4 Joined Apr 2011 More info | Jan 16, 2015 16:12 | #1 Tommorow will be buying slighly used 7D Mark II.
MalVeauX "Looks rough and well used" More info | Jan 16, 2015 20:13 | #2 Heya,
Jan 17, 2015 08:07 | #3 Shift7 wrote in post #17385918 2. There is infamous > 100 pages 7D Mark II AF issues thread, so what I should check before buying it? Nothing. You should, however, check the manual before using the camera. Frank Hollis - Retired mass spectroscopist
ppmax Member 177 posts Likes: 36 Joined Feb 2009 More info | I would read the thread. You will find several people that have sent their 7D2 to canon to have AF issues diagnosed and fixed due to legitimate defects in assembly. They are happy campers now...but these clearly were not related to not "reading the manual" as the post above implies.
ReservoirDog A Band Apart More info | Jan 17, 2015 20:59 | #5 IMHO, when you have an infamous 100 pages about issues, even knowing that people usually make a lot of "noise" for nothing, it might be possible that there is some true somewhere ... Patrice
Craign Goldmember More info Post edited over 8 years ago by Craign. (2 edits in all) | Jan 18, 2015 08:08 | #6 Look at this >200 page thread if you have questions about the quality of photos from the 7D2 camera. These photographers know how to use it and give great advice concerning settings. Canon 7D Mark II w/Canon BG-E16 Battery Grip; Canon EOS 50D w/Canon Battery Grip; Canon SL1; Tokina 12mm - 24mm f/4 PRO DX II; Canon EF 24-105mm f/4L IS; Canon EF 70-200mm f/2.8L IS; Canon 70-300mm f/4-5.6L IS; Sigma 85mm f/1.4 EX DG HSM; Canon EF 300mm f/4L IS; Canon EF-S 18-135mm f/3.5-5.6 IS STM; Canon Extender EF 1.4x II; Canon Extender EF 2x II; Canon Speedlite 430EX II Flash
huntersdad Goldmember 4,870 posts Likes: 652 Joined Nov 2008 More info | Jan 18, 2015 12:01 | #7 You need to test it on a moving subject. I returned 2, my 3rd is looking very good. The tracking sucked on the previous 2. This one is good. Facebook
agedbriar Goldmember 2,657 posts Likes: 399 Joined Jan 2007 Location: Slovenia More info Post edited over 8 years ago by agedbriar. | Jan 18, 2015 17:52 | #8 huntersdad wrote in post #17388277 You need to test it on a moving subject. I returned 2, my 3rd is looking very good. The tracking sucked on the previous 2. This one is good. Reading the manual for the third time resolved your issue, obviously.
huntersdad Goldmember 4,870 posts Likes: 652 Joined Nov 2008 More info | Manual is still the wrapper. Operating a camera isn't rocket science. -it either works or it doesn't. 3rd time is a charm. Facebook
agedbriar Goldmember 2,657 posts Likes: 399 Joined Jan 2007 Location: Slovenia More info | Did you miss my second line above?
huntersdad Goldmember 4,870 posts Likes: 652 Joined Nov 2008 More info | Jan 18, 2015 18:52 | #11 agedbriar wrote in post #17388781 Did you miss my second line above? My apologies, I did. Facebook
LarryJohnson Goldmember More info Post edited over 8 years ago by Larry Johnson. | Jan 18, 2015 18:53 | #12 Shift7 wrote in post #17385918 Tommorow will be buying slighly used 7D Mark II. 1. Which program, can tell me it's shutter count? 2. There is infamous > 100 pages 7D Mark II AF issues thread, so what I should check before buying it? Thanks This might give you some ideas. https://photographylife.com/how-to-buy-used-dslr-cameras _______________
Jan 19, 2015 03:48 | #13 agedbriar wrote in post #17388728 I remember the 1D3 "user errors" all too well. What, when Canon admitted a fault and recalled the affected batch? Yes, I remember that well. However, I've totally forgotten about them doing the same for the 7D and the 70D - both of which also suffered from equally bad problems (so I seem to recall). Frank Hollis - Retired mass spectroscopist
agedbriar Goldmember 2,657 posts Likes: 399 Joined Jan 2007 Location: Slovenia More info | Yes, in the case of the 1DmkIII it took Rob Galbraith's reputation and persistence plus a full HD of samples shot in the presence of Canon representatives with a thoroughly checked camera they brought along, for Canon to finally issue the recall.
| Latest registered member is Sandro Bisotti 1611 guests, 159 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
