A couple bucks while buying dog food gets you an aquarium to play with.
IMAGE LINK: https://flic.kr/p/qzcDzV
IMAGE LINK: https://flic.kr/p/qzcDDH
Strick Senior Member More info | Jan 20, 2015 19:58 | #1 A couple bucks while buying dog food gets you an aquarium to play with. IMAGE LINK: https://flic.kr/p/qzcDzV IMAGE LINK: https://flic.kr/p/qzcDDH
saea501 ... spilled over a little on the panties More info | Jan 21, 2015 06:12 | #2 It's interesting what the dimples on the golf ball do to the water flow. Remember what the DorMouse said.....feed your head.
TeamSpeed 01010100 01010011 More info | Jan 21, 2015 06:35 | #3 Now try to get your hands on some colored LED lights and shine them through the water at different angles to get some cool effects. Past Equipment | My Personal Gallery
birderman Goldmember 1,052 posts Likes: 44 Joined Mar 2011 Location: London, UK More info | I guess its a good demonstration of the importance of the dimples for ensuring the golf ball flies straight and far.... Birderman
readytosnap Senior Member 727 posts Likes: 1290 Joined Jan 2014 More info | Jan 22, 2015 09:51 | #5 Great shots. What was your setup for theses and what shutter speed? Thanks
Jan 22, 2015 09:58 | #6 https://photography-on-the.net …showthread.php?p=17391550
Jan 26, 2015 03:32 | #7 Interesting shots. I like the golf ball. To fill some of the negative space you could insert a rubber tube into the bottom of the tank and blow hard as you take the shot, which will create a further bubble pool around the object dropped. You will look a bit strange doing that, so I'd wait until you are alone in the house! Canon EOS 5D Mark II • EOS Digital Rebel XT / EOS 350D / Kiss Digital N | Panasonic Lumix DMC-G6 | Canon EF 100mm f/2.8L Macro IS USM • EF 28-105mm f/4-5.6 USM • EF 50mm f/1.8 II | Sigma 15mm f/2.8 EX Fisheye • 105mm f/2.8 Macro EX | Nissin Di866 Mark II Flash | Sigma EM-140 DG Macro Ring Flash | Canon Speedlite 430EX II | Yongnuo YN460-II
spyderpig Member 193 posts Likes: 14 Joined Mar 2011 More info | Jan 28, 2015 20:51 | #8 As an engineer, I find the golf ball one fascinating. T2i | Canon 15-85mm | kit 55-250mm | Sigma 80-400mm
| Latest registered member is semonsters 1454 guests, 128 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
