This is 28 images stack and 2 darks all averaging 5-8 secs each . Mainly I was testing the 135mm f/2.8 with camera on a tripod just to see how well it handled . I thought it did well .
Celestron Cream of the Crop More info Post edited over 8 years ago by Celestron. | Jan 20, 2015 23:18 | #1 This is 28 images stack and 2 darks all averaging 5-8 secs each . Mainly I was testing the 135mm f/2.8 with camera on a tripod just to see how well it handled . I thought it did well .
Jan 21, 2015 11:38 | #2 How is using manual focus lenses with their hard infinity focus stops? I lost one stack of shots because as the lens was cooling down the focus was shifting. I'm in Canada. Isn't that weird!
Jan 21, 2015 12:10 | #3 AbPho wrote in post #17393119 How is using manual focus lenses with their hard infinity focus stops? I lost one stack of shots because as the lens was cooling down the focus was shifting. What caused the shifting ? Did you bump your tripod or camera ? The MF lens i have are snug so i have no problem with shifting . But also too it's a prime lens , not a zoom lens .Also being an older lens the Pentax SMC 135mm f/2.8 has a builtin hood so that may account for the snugness . But the lens is tight . I use a Canon adapter for PK lens attachments . Here is the same at BhPhoto but i bought mine on ebay over 13 years ago . They are very good lens if you can get your hands on one . As far as focus to infinity i just adjust all the way to infinity then slightly back off , take a test shot and if the stars are good focus i leave alone but if out of focus i'll refocus , really simple .
samsen Cream of the Crop 7,468 posts Likes: 239 Joined Apr 2006 Location: LA More info | Jan 21, 2015 17:04 | #4 Ron: nice and which Pentax is this? Takumar 42mm mount or PK? AbPho wrote in post #17393119 How is using manual focus lenses with their hard infinity focus stops? I lost one stack of shots because as the lens was cooling down the focus was shifting. That is the exact reason you should never use AF for astro. This is probably one of those rare occasions where Manual Focus lens is as good or sometimes better. Weak retaliates,
Jan 21, 2015 18:02 | #5 samsen wrote in post #17393579 Ron: nice and which Pentax is this? Takumar 42mm mount or PK? That is the exact reason you should never use AF for astro. This is probably one of those rare occasions where Manual Focus lens is as good or sometimes better. Not a Takumar , it's a Pentax PK mount like this one : http://www.pentaxforums.com …ax-A-135mm-F2.8-Lens.html
Jan 21, 2015 18:10 | #6 I was not using auto focus. I said the focus shifted through the range of images for the stack. I assume it was from the lens cooling down to -27ºC from +15ºC (inside the car). Once I noticed and readjusted the lens was fine for the second stack of 49 images. I'm in Canada. Isn't that weird!
Deepsiix Member 30 posts Joined Jan 2009 Location: Winnipeg More info Post edited over 8 years ago by Deepsiix. | Jan 21, 2015 20:32 | #7 is this the subaru constellation?
Jan 21, 2015 22:12 | #8 Deepsiix wrote in post #17393894 is this the subaru constellation? Pleiades is M45 . Not considered a constellation . It's the closest Open Star Cluster to earth : http://en.wikipedia.org/wiki/Pleiades
samsen Cream of the Crop 7,468 posts Likes: 239 Joined Apr 2006 Location: LA More info Post edited over 8 years ago by samsen. | Jan 21, 2015 22:43 | #9 Deepsiix wrote in post #17393894 is this the subaru constellation? Celestron wrote in post #17394048 Pleiades is M45 . Not considered a constellation . It's the closest Open Star Cluster to earth : http://en.wikipedia.org/wiki/Pleiades
Weak retaliates,
| Latest registered member is semonsters 1573 guests, 136 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
