Thread started 22 Jan 2015 (Thursday) 19:22
I won a contest and I have a choice of two prize packages from PocketWizard. Help me decide?
chexjc
Joined Sep 2014
Jan 22, 2015 19:22 |  #1
Hi!
So I won PocketWizard's Dec 2014 Photo Contest (external link) and I have a choice between two prize packages.
Prize 1
  • 1 MiniTT1 Transmitter
  • 2 FlexTT5 Transceivers
  • 1 AC3 ZoneController
Prize 2
  • 3 Plus III Transceivers
  • G-Wiz Squared Bag
Now, I understand (for the most part) the different offerings of these flash/camera triggers, but I'm not sure which one is better for me. As far as lighting gear goes, I currently only own a Yongnuo 468 ii TTL speedlite and umbrella/stand. I use Yongnuo RF-603C's to remotely trigger the flash. My understanding is that the TTL functionality of Prize 1 may or may not work with my Yongnuo flash. That's not to say I couldn't purchase a Canon speedlite if that were the practical thing to do here. In my brief research, I've also encountered mention of reliability issues with basically all of these triggers -- perhaps those were all resolved by firmware updates?
With regards to what I shoot (mainly portraits), I don't see a ton of need for TTL ability in my triggers, but perhaps I should? Being that the MiniTT1/FlexTT5 appears to offer (mostly) what the Plus III's do plus TTL compatibility, are they the better option? Are the Plus III's more reliable? Will they function with my Yongnuo 468 ii? Which would you choose?
Thanks for any advice! I want to get back to them tomorrow with my choice, so any insight is appreciated!
Canon 6D x2 | 17-40L | Sigma 35 ART | 50mm f1.8 STM | 85mm f1.8 | 135L
Website (external link) | Instagram (external link) | flickr (external link)
Alveric
Gallery: 38 photos
Jan 22, 2015 20:37 |  #2
I'd go with option #2. You'll need to buy adaptors and cables to trigger your current flashguns with them, but if you ever move onto studio strobes the Plus III's are better than the Flex's.
I have Flex's and PlusX's. They all work awesomely, but I hardly ever use TutTutL.
Methodical
Gallery: 239 photos
Post edited over 8 years ago by Methodical. (2 edits in all)
Jan 23, 2015 02:34 as a reply to  @ Alveric's post |  #3
Congrats on winning.
I've never used the PlusIII, but I do have the Flexes and Yougnous. With the flex and the AC3 zonecontroller (use with the Einstein), you have so much control over various flashes in the 3 zones (A, B, C) right at the controller. For instances, you can adjust the flash output without ever having to touch or going over to any of the flashes directly from the zone controller on the camera. Plus you can trigger the flashes without having to purchase any cables or triggers or whatnot. This is good if you ever decided to use a light meter, which would save you some money because you don't to purchase a meter with an expensive module to trigger the flash to measure light output. If you have a few days to decided, I say check out the features of both. There's so much you can do with the Flexes.
Alveric, what are the differences or issue/nonissue you've experienced using the Flex vs the PlusIII? I think if you define that, it would give the OP a better understanding of why you like one over the other and possibly a better reason to choose one over the other. I am curious, too.
Al
Gear
MethodicalImages (external link)
"Never be afraid to try something new. Remember, amateurs built the Ark, professionals built the Titanic"
chexjc
Joined Sep 2014
Jan 23, 2015 04:52 |  #4
Alveric wrote in post #17395514 (external link)
Thanks for the reply! What adaptors and cables would I need to fire the Yongnuo? I was under the impression that the Plus III's might work well with the Yongnuos being that the signal sent isn't carrying anything complicated like the e-TTL information.
Methodical wrote in post #17395815 (external link)
Al
Thanks for all the info! So just to be clear, can the Flex fire your Yongnuo flash? If so, which Yongnuo do you have? It's pretty awesome the way that the AC3 allows you to adjust flash output from the camera. I'm enticed by that feature even though its something I don't have the gear to take advantage of at the moment. That's what makes this decision so hard...:-)
Methodical
Gallery: 239 photos
Jan 23, 2015 14:52 |  #5
chexjc wrote in post #17395901 (external link)
Sorry for the confusion. I don't have Yongnou flash, I have the flash triggers. You have the gear to use the system now; your flashes. If don't need it, you can always sell it. I am not versed on the Yongnuo flashes, but from the little bit I've seen they are Canon clones, so operation should be the same or at least very similar. Don't rush the decision if you have time to choose. Think ahead.
Good luck, this is a good problems to have :p
Gear
Alveric
Gallery: 38 photos
Post edited over 8 years ago by Alveric.
Jan 23, 2015 15:10 |  #6
The Plus's don't have hot shoes, that's why you'll need a hot shoe adapter to use it with a flashgun.
This is the adapter: http://www.pocketwizar​d.com …/flash_sync_cab​les/hsfm3/ (external link)
Note that the Plus's already come with a flash synch cable (and probably the adapter from MM3 to MP3, at least my PlusX's did), but the HSFM cable must be purchased separately.
Flex's have a hot shoe, but don't come with any cables: if you want to use them with your studio strobes and/or want to trigger your camera remotely you'll have to order the pertinent cables: MM3 or MP3 and whichever of these (external link) fits your camera.
Regarding zones: Plus III's already come with zones (and buttons for them), so you wouldn't need the AC3 adapter. Flex's support zones but don't have buttons for them, that's why you need the AC3.
I don't have the Plus III's, but the PlusX's. These latter ones are simple triggers, they support channels but not zones.
You can take a look at all the features and differences among those units in this document (external link).
Methodical
Gallery: 239 photos
Jan 23, 2015 15:17 |  #7
Alveric wrote in post #17396634 (external link)
It sounds like they both do the same thing, except the Flex allows you to use ETTL (i.e. automatic settings) and you can also get higher flash sync speeds with the Flex, up to 8000 with certain strobes, such as Alien Bees, which allows you to use flash with larger apertures (i.e. f2, 2.8 etc) without resorting to ND filters.
Gear
Alveric
Gallery: 38 photos
Jan 23, 2015 15:22 |  #8
Al
Methodical, the only issues I've experienced with the Flex's is a limited range in shutter speeds with the Metz 58 AF-2 when using HSS: once you get past 1/1600 sec you'll get half the frame underexposed: no, not half the frame black, but underexposed; weird problem I know. Surprisingly, this doesn't happen with the Flex and the Canon 430EX II, even all the way to 1/8000 sec, go figure. I did mention the problem to PW during one of their webinars, in the chat channel, but I never followed through. After my Metz flash buying the farm, it's a moot point now anyway, but I think this problem stems from PW being forced to reverse engineer other manufacturer's equipment. That's one problem I've had with the Flex's.
Another problem is inconsistencies with the remote camera triggering using the Flex/Mini combo. One extra item here: with the Flex's, when triggering both camera and flashes remotely, the sync speed will remain as normal (1/200 sec in the case of my 5D2), but when using the PlusX's, you'll have to lower the shutter speed to 1/160 sec or you'll get the second curtain black bar, very slightly, but still: I don't care for this, even though it's only 1/3 stop. However, when NOT using the remote camera triggering, the Plus's do synch at the camera's max sync speed without a hitch.
1,641 views & 0 likes for this thread, 3 members have posted to it and it is followed by 2 members.
1505 guests, 131 members online
