Thread started 25 Feb 2006 (Saturday) 01:29
Speedlite 580 EX Battery Issues
lesvisages
Feb 25, 2006 01:29 |  #1
I seem to only get about 25 good flashes from my Speedlite 580 EX flash with certain batteries. I am using the Quantary (by Sunpack) 2500 NiMH batteries. After 25 flashes, the recycle time is about 10 seconds. When I remove them they are extremely hot to the touch. I have recently burned up a 580 EX flash unit that way. I do not want to repeat that again. I rotate between 50 bateries or so. They have been purchased in all in the last two months. I recharge them in the 90 min charger after I use them. I do a lot of work in nightclubs and frquently have to change batteries. Is this normal? Should I upgrade to the battery pack?
THE FACADE ENTERTAINMENT GROUP (external link)
Les Visages Creative
rik@lesvisages.com (external link)
cdifoto
Don't get pissy with me
Feb 25, 2006 01:32 |  #2
Try another brand of NiMH like Duracell. I have great results with those in my 580EX. You could also try some standard Alkalines and see how they do. My Duracell NiMH batteries get a little warm but certainly not hot...and they last much longer than 25 shots with good recycle times. I have 5 sets (20) of them and they last a good long time.
Rumjungle
Feb 25, 2006 01:48 |  #3
I've been using the cheap-o Power2000's from B&H. 2700mah and they seem to last a good while.
Are you taking lots of shots in rapid succession? I can see that you would have a heat issue if that were the case.
Gear
zirkonium
Feb 25, 2006 02:44 as a reply to  @ Rumjungle's post |  #4
Same unit, Energizer 2500mAh batteries, using Canon's battery charger and it takes a few hours to fully charge. But batteries last much longer. No complaints here.
René ­ Damkot
Feb 25, 2006 06:37 |  #5
You say 'certain' batteries. Do a test and mark these batteries. Then don't use 'em again, I'ld say they were faulty....
25 Flashes is not nearly enough, even at full power. I don't flash that much / hard, so I don't know much about it, but I would expect a flash tube to overheat before a battery. Maybe some bad connection in the batteries internal?
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
SkipD
Joined Dec 2002
Feb 25, 2006 07:30 |  #6
Definitely sounds like high resistance inside the batteries.
I would never again buy anything with the Quantaray label on it except for something that I can totally inspect such as a camera bag. Most everything I have seen private-labelled as Quantaray has been essentially bottom-of-the-barrel junk.
Skip Douglas
Harry ­ Settle
Joined Jun 2004
Feb 25, 2006 09:16 as a reply to  @ SkipD's post |  #7
I use only the Energizer 2500's with no problem. If you are a battery-hog, like me, try these slow chargers. They take longer, but your batteries should last longer, and you can charge 10 batteries at the same time.
www.batteryspace.com (external link)
lovelace415
Feb 25, 2006 10:03 |  #8
I use Energizer 2500's as well with no problems whatsoever. I have the 15 minute charger which I know is not good for them but I get A LOT of shots off of a set before I have to recharge. Seems like something is wrong with your batteries or possibly the flash itself?
Canon 350 XT
Canon 18-55mm Kit, 50mm 1.4, 85mm 1.8, 100mm 2.8 Macro, 135mm 2L, 200mm 2.8L, 1.4X Tele
Canon 580EX(2)
Sigma 24-70mm 2.8X
cdifoto
Feb 25, 2006 10:06 |  #9
My money's on the batteries being bad. I mean...come on...Quantaray? heh.
Dan ­ GSR
Feb 25, 2006 13:09 |  #10
yup, throw the batteries away
get some quality batteries....energizer or sanyo......etc
Canon 1D Mark II | Canon 24-70 f/2.8 L| Canon 50 f/1.4 USM | Canon 70-200 f/2.8 L USM
Canon 580EX | Manfrotto 679B Monopod
vjack
Feb 25, 2006 14:04 as a reply to  @ Dan GSR's post |  #11
I found this helpful: http://www.imaging-resource.com/ACCS/BATT​S/BATTS.HTM (external link)
Canon 20D
Canon EF-S 10-22mm f/3.5-4.5 USM
Sigma 18-125mm f/3.5-5.6 DC
Tamron 28-75mm f/2.8 XR Di LD
Canon EF 50mm f/1.8 II
Canon EF 70-200mm f/4L
Canon EF 100-400mm f/4.5-5.6
L IS
Canon Speedlite 430EX
Manfrotto 3021BPRO; Kirk BH-1 ballhead
Canon Pixma 4200
< see my gallery (external link) >
snibbetsj
Joined Jun 2004
Feb 27, 2006 09:47 as a reply to  @ vjack's post |  #12
Definitely get rid of those batteries. I use the Duracell NiMH (I get 'em at Wal-Mart) in my 580 and 420. Typically I'll get 120-150 flashes before having to change batteries. Batteries are cheap, the 580 isn't.
Jeff Stebbins
Amorous
Feb 27, 2006 17:45 as a reply to  @ snibbetsj's post |  #13
Here's another Energizer 2500 mAh user. No complaint.
My web site: http://kaitcilla.smugm​ug.com/ (external link)
Los Angeles area local photography group: http://lashooters.org (external link)
tim
Light Bringer
Feb 27, 2006 18:57 |  #14
Try the energisers. The problem could be with your charger, I had the same problems recently.
Kostyanych
Joined Jan 2005
Feb 28, 2006 10:34 |  #15
Another vote for Energizer 2500's.
Canon 7D | EF-S 10-22 F/3.5-4.5 | EF 24-105 mm F/4L IS USM | EF 70-200 F/2.8L IS USM | EF 50 mm F/1.4 USM | EF 85 mm F/1.8 USM | 580EX II| TC-80N3 | Gitzo G2220 tripod | Manfrotto 329RC4 head | Dynatran AT-CF992 tripod | Newton Bracket Di100FR2 | 2 x POTN Op-Tech Strap | 4 x Hensel Integra 500 Pro | 2 x PW Plus II | Sekonic L-758D | Dynatran AS-014-2
2,441 views & 0 likes for this thread, 15 members have posted to it.
1810 guests, 101 members online
