according to the instruction manual I think I should be able to use my 300TL speedlite with my 20D on manual mode but I can not get it to fire - any advice appriciated
broon Member 188 posts Likes: 1 Joined Jan 2006 Location: north east england More info | Feb 25, 2006 06:35 | #1 according to the instruction manual I think I should be able to use my 300TL speedlite with my 20D on manual mode but I can not get it to fire - any advice appriciated Canon 20D, Sigma 50 - 500, Canon 28-80mm kit lens
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Feb 25, 2006 10:49 | #2 What's in manual mode, the flash or the camera, or both? They both should be if, in fact, the flash does work on the 20D. ...Leo
Feb 25, 2006 11:53 | #3 Thanks PaCace, both are in manual and the 300tl works ok on my t90 Canon 20D, Sigma 50 - 500, Canon 28-80mm kit lens
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Feb 25, 2006 19:17 | #4 Here's something you can try. Place two pieces of tape on the camera hot shoe so that the two pin contacts on each side of the hot shoe are covered (4 pin contacts all together) leaving only the center bigger contact exposed. Mount the flash again and see if that works. If it does, then the 300tl may not really be compatible with the digital EOS cameras, even in manual mode, unless the appropriate pins are covered up. ...Leo
| Latest registered member is Thunderstream 998 guests, 103 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
