What 50mm prime is the fastest with the quickest autofocus non L glass? I have the 85mm 1.8 and would like something a little wider. I'm shooting with the 7D II
Jan 28, 2015 18:33 | #1 What 50mm prime is the fastest with the quickest autofocus non L glass? I have the 85mm 1.8 and would like something a little wider. I'm shooting with the 7D II
Jan 28, 2015 19:10 | #2 Permanent banEF 50mm f/1.4. WARNING: I often dispense advice in fields I know little about!
Is the auto focus comparable to the 85mm 1.8?
Jan 28, 2015 19:32 | #4 Permanent banjlstan wrote in post #17404831 Is the auto focus comparable to the 85mm 1.8? I don't currently own the 85 1.8, but I used to. I do have both the 100 f/2 (85 1.8's big brother) and the 50 1.4. To answer your question in one word: NO. It is micro-motor, not USM. I think you'll be fine shooting from the stands. Action will predominantly be moving sideways, up and down the court. It may not be sufficient for fast-approaching action under the basket. For $300, it is worth a try. WARNING: I often dispense advice in fields I know little about!
InfiniteDivide "I wish to be spared" More info Post edited over 8 years ago by InfiniteDivide. | Jan 28, 2015 20:56 | #5 Perhaps the EF-S 60mm USM would work? James Patrus
I've been shooting to hold 1/1000 using auto iso most of my shots are around F2. The courts are quite dark
MotorOn Senior Member 941 posts Likes: 52 Joined Feb 2007 More info | Jan 28, 2015 21:39 | #7 50 1.4 is exactly what you're looking for, I put the 50 on whenever we hit the last 2min or go into OT, if I'm near the basket it's the safety lens that I feel like no matter what I can get something with it (even if I need a little cropping). IMAGE LINK: http://www.dcanavanphoto.com/p467815066/e4a81194 Website
MalVeauX "Looks rough and well used" More info | Jan 28, 2015 21:45 | #8 jlstan wrote in post #17404751 What 50mm prime is the fastest with the quickest autofocus non L glass? I have the 85mm 1.8 and would like something a little wider. I'm shooting with the 7D II Heya,
Jan 28, 2015 22:31 | #9 Permanent banMalVeauX wrote in post #17405029 Heya, Well, there's 3 main Canon 50mm lenses that are modern. Or, semi-modern, if you will. The 50 F1.4 is USM. The 50 F1.8 II is not, and is slow to focus. The 50 F1.2 is L, so out of the tier that you're talking about. Other than that, there's Sigma's non-ART 50, which is good, but not as fast as Canon's USM's. So realistically, 50 F1.4 USM if you just want AF speed and decent optics. Are you sure you need 50mm? On APS-C, I would actually be perhaps considering 35mm to have a good contrast to the 85mm length, instead of something fairly close. Very best, The 50 1.4 is micro-motor USM, just like the 70-300. Neither are ring-type USM. Neither are particularly fast at focusing. WARNING: I often dispense advice in fields I know little about!
Jan 29, 2015 13:11 | #10 I definitely would not recommend the 50 1.8 for hoops--been there, tried that. Focus was just too slow/unreliable. The 100/2 was very good for hoops, the 135L even better. I shot the older model sigma 30 1.4 after I sold the fifty and found it better under the basket than its predecessor. All of this was on the 60D. Sony A7RIII, Tamron 28mm 2.8 Di III OSD M1:2, Sonnar T* FE 55mm f/1.8 ZA, Canon 200mm 2.8L ii, Sigma MC-11, HVL-F43M
Voaky999 Goldmember More info | Jan 29, 2015 13:47 | #11 Used the Sigma 50A a couple of weeks ago, worked pretty well Don
gqllc007 Senior Member 445 posts Likes: 133 Joined Jan 2015 More info | I shoot high school basketball from just back and under the net. The lighting is awful usually 8000ISO just to get 1/500 . I have 7DmkII and have shot with the 85 1.8, 70-200 2.8 and the 24-70 2.8 mk2 I get far and away more successful images with the 24-70 2.8 because of where I shoot from. However even using a white balance expodisc I still have a difficult time with noise. I use AI servo, case 2, focus priority 1st and second image, flicker enabled I wish I could use a strobe but the kids like the pics so it is good enough
TeamSpeed 01010100 01010011 More info Post edited over 8 years ago by TeamSpeed. (2 edits in all) | Jan 29, 2015 13:59 | #13 How about the Sigma 18-35 1.8? That might fit the bill? Past Equipment | My Personal Gallery
Jan 29, 2015 14:20 | #14 A lens frequently used for 50mm framing at basketball game is the Canon 24-70mm f2/8.
bubbygator I can't tell the difference 1,477 posts Gallery: 1 photo Likes: 63 Joined Feb 2011 Location: Sarasota, sunlight, butterflies, fish, Gators, and Seminoles More info | Jan 29, 2015 14:58 | #15 Like others, I went through the "50/1.8 is too slow" phase. Gear List
| Latest registered member is semonsters 1215 guests, 110 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
