I want to upgrade my cheap Dolica set up and looking at buying this MeFoto..any one have/had it ??how did you like it,,i would use it hikeing,backpacking,,traveling,and general use...with a 7D and 100-400 IS Canon..
Ron
RonnieH Goldmember 1,793 posts Likes: 53 Joined Feb 2009 Location: Twining, Michigan USA More info | Jan 29, 2015 12:29 | #1 I want to upgrade my cheap Dolica set up and looking at buying this MeFoto..any one have/had it ??how did you like it,,i would use it hikeing,backpacking,,traveling,and general use...with a 7D and 100-400 IS Canon..
LittlejonDsgn Goldmember 3,266 posts Likes: 905 Joined Feb 2012 Location: Sandy, Oregon More info | Jan 29, 2015 15:33 | #2 I have the aluminum Globetrotter and love it thus far. I also upgraded from a Sunpak 423PK. Something to keep in mind that the globetrotter will not fit in the bag unless you reverse the legs which is kind of a bummer but this was nothing new to me as I played around with it in the store. I also picked up a short column as I never extend the center columns and this allows me to get even close to the ground.
Jan 29, 2015 19:12 | #3 I like mine as well although after a year I'm thinking about upgrading the ball head. It sags a little after tightening with the 55-250. my gear: T4i - EF-s 17-55, Ef-s 55-250 is stm, EF-S 10-22 usm, ef 100mm 2.8 macro
Jan 30, 2015 08:54 | #4 TerryMiller wrote in post #17406308 You need to hang a camera bag or something from the center column and use a cable release to get rock solid images. This tells you (the OP) something about the tripod, and you have a 400mm lens... ~Peter
LittlejonDsgn Goldmember 3,266 posts Likes: 905 Joined Feb 2012 Location: Sandy, Oregon More info | Jan 30, 2015 10:08 | #5 TerryMiller wrote in post #17406308 I like mine as well although after a year I'm thinking about upgrading the ball head. It sags a little after tightening with the 55-250. You need to hang a camera bag or something from the center column and use a cable release to get rock solid images. I have not experienced the need to hang a bag, I was able to get sunrise images with mine with new added weight hanging and using the 10 second timer built into the camera (I had ran out of the house withut my cable release). Then again I dont shoot very often with more then 2 sections extended, I like to shoot low to the ground.
Jan 31, 2015 14:11 | #6 It could just be my technique that makes causes movement. I shoot with the legs fully extended and the center column partially extended to get the viewfinder at eye level. my gear: T4i - EF-s 17-55, Ef-s 55-250 is stm, EF-S 10-22 usm, ef 100mm 2.8 macro
LittlejonDsgn Goldmember 3,266 posts Likes: 905 Joined Feb 2012 Location: Sandy, Oregon More info | That might be part of it. I switched my center column to a short version which does not extend at all. While shooting yesterday I never extended more then two sections of legs.
Nick5 Goldmember More info | Feb 03, 2015 08:11 | #8 Ronnie H wrote in post #17405785 I want to upgrade my cheap Dolica set up and looking at buying this MeFoto..any one have/had it ??how did you like it,,i would use it hikeing,backpacking,,traveling,and general use...with a 7D and 100-400 IS Canon.. ------------- Ron Ronnie. Canon 5D Mark III (x2), BG-E11 Grips, Canon Lenses 16-35 f/4 L IS, 17-40 f/4 L, 24-70 f/4 L IS, 70-200 f/2.8 L IS II, 70-200 f/4 L IS, 70-200 f/4 L IS Version II, 100-400 f/4.5-5.6 L IS Version II, TS-E 24 f/3.5 L II, 100 f/2.8 L Macro IS, 10-22 f3.5-4.5, 17-55 f/2.8 L IS, 85 f/1.8, Canon 1.4 Extender III, 5 Canon 600 EX-RT, 2 Canon ST-E3 Transmitters, Canon PRO-300 Printer
Feb 04, 2015 16:19 | #9 I have the aluminum version and love it. Small and light, decent ball head. If I need extra stability I don't extend the last leg parts, they are pretty thin, but that's the same with any compact/travel tripod. I mostly shoot handheld, so getting some $1000 carbon fiber extravaganza was out, I have an xprob 190 too, but that got too heavy and big for my taste when hiking. I've not had to hang anything from the center for stability, but I plan to trow a bungie cord into my bag for that purpose. My full bag would be too heavy, but I think if I place the bag on the ground underneath and use a short bungie on the tripod to tighten down to the bag I'll get all the extra stability I'll need. 40D, 5D3, a bunch of lenses and other things
freestylee30 Senior Member More info Post edited over 8 years ago by freestylee30. | I'm happy to have found this thread and read your guys' positive reviews! Brandon | zenfolio
Feb 09, 2015 17:53 | #11 freestylee30 wrote in post #17424050 I'm still not sure about the head/plate that comes with the MeFoto. I'd be curious to know what do you guys think about it? MeFotos are OEM'd by Benro with a few corners cut off the standard Benro fare. Benro make good tripods but their ballheads are mostly not that great. I'd sell the ballhead while it's new and buy a small Sirui head like the K-20X. ~Peter
LittlejonDsgn Goldmember 3,266 posts Likes: 905 Joined Feb 2012 Location: Sandy, Oregon More info | After 2 full days of use in Sedona I have zero complaints about the globetrotter or the included head.
Feb 10, 2015 07:35 | #13 Glad to hear that it's working properly on receipt. There's a fair amount of product variation so you're going to have to wait a while to assess its durability. ~Peter
LittlejonDsgn Goldmember 3,266 posts Likes: 905 Joined Feb 2012 Location: Sandy, Oregon More info | That's kinda like everything. Only time will tell. I have high hopes and from what I can see this tripod will hold up to them. The thing is you can't expect it to perform like a $1000 set up. You have to have realistic expectations.
freestylee30 Senior Member More info | Feb 10, 2015 09:25 | #15 Littlejon Dsgn wrote in post #17425225 That's kinda like everything. Only time will tell. I have high hopes and from what I can see this tripod will hold up to them. The thing is you can't expect it to perform like a $1000 set up. You have to have realistic expectations. Yep, I agree. Like I said above, up until now, I haven't hiked/backpacked with a tripod because what I had was too heavy and cumbersome. This ~$400 setup will allow me to at least bring something along now. Can't wait to try it out. Brandon | zenfolio
| Latest registered member is semonsters 1099 guests, 120 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
