I have been working with my Tammy 150-600 to try to make it take sharp pics on my 7DII. This is my latest effort. I don't think it is as sharp as I want it to be, but close.
Jan 31, 2015 20:40 | #1 I have been working with my Tammy 150-600 to try to make it take sharp pics on my 7DII. This is my latest effort. I don't think it is as sharp as I want it to be, but close.
recrisp Goldmember More info | Jan 31, 2015 20:51 | #2 It looks like you have it really, at least the shots I see on your Flicker. If you have the eyes in perfect focus, then you can't do anymore than that, I don't think.
2n10 Cream of the Crop More info | Jan 31, 2015 21:16 | #3 Joel, beautiful shot. It looks to be very close if not there.
Beekeeper Goldmember More info | Jan 31, 2015 21:21 | #4 Looks good to me. Zach--C&C is welcome on my photos
Jan 31, 2015 22:48 | #5 I took the shot at about 30 feet. My micro adjust was +13 on my 7DII at the telephoto end. I haven't tried to adjust the short end yet since I almost always use this lens at 600mm. If it were a 600 prime, then I would get just as much use out of it as I do now.
Peter2516 Cream of the Crop More info | Jan 31, 2015 23:37 | #6 Great shot looks good to me also. Peter
fogboundturtle Senior Member 735 posts Likes: 36 Joined Mar 2010 More info | Feb 01, 2015 00:47 | #7 You need to shoot at F8 for maximum sharpness and use a tripod + gimbal for maximum acquisition rate Canon 5D Mark III, Canon 70D, Canon EF 24-105L, Tamron 150-600mm, Tamron 70-200 F2.8 DI VC USD, Sony A7r, Sony FE 55mm F1.8
DuaneN Cream of the Crop More info | Feb 01, 2015 04:19 | #8 It looks as if you're dealing with a dof issue rather than a sharpness issue. I shoot my backyard birds at 23'-26' distance at 500mm-700mm and depending on which way they sit I can never get the entire bird in focus. I shoot from f/8 to f/13 and still deal with the focus (or sharpness) falling off from the focal point of the lens/camera.
Marc451814882 Member 129 posts Likes: 8 Joined Aug 2006 More info Post edited over 8 years ago by Marc451814882. (2 edits in all) | Feb 01, 2015 05:12 | #9 Duane N wrote in post #17409687 It looks as if you're dealing with a dof issue rather than a sharpness issue. I shoot my backyard birds at 23'-26' distance at 500mm-700mm and depending on which way they sit I can never get the entire bird in focus. I shoot from f/8 to f/13 and still deal with the focus (or sharpness) falling off from the focal point of the lens/camera. Dear sir, Marc 5d-mkIII - 7d and some glass
2n10 Cream of the Crop More info | Feb 01, 2015 06:38 | #11 The 7D figures should be just fine to use as the sensor size is what controls the DOF not megapixels. The Canon APS-C sensors are within .1mm in length and width measurements. When this is converted into an area it should still be in the rounding error range or quite close to it. Testing wide open is correct you then need to select the correct aperture to achieve the DOF you have in mind.
recrisp Goldmember More info | I also did an adjustment on my 1D mkIV and my Tamzooka, I also did it at (only) 30 feet to see what it would accomplish, I had it SUPER sharp! That means it was sharp at close ranges up to 30-ish feet, longer than that and it didn't looks sharp at all. (I had it -15)
Marc451814882 Member 129 posts Likes: 8 Joined Aug 2006 More info | Feb 01, 2015 08:05 | #13 guntoter wrote in post #17409755 Wow, .17 ft. for a DOF. That is thin. I need to close that aperture some when the light is good. Thanks for the tip guys That's a good idea Sir. And remember the achieved dof is not only diafragma but works in combination with distance to subject. 5d-mkIII - 7d and some glass
CamFan01 Goldmember 4,623 posts Likes: 33 Joined Jul 2010 Location: Lilburn, GA More info | Feb 01, 2015 08:12 | #14 Might I suggest to you Joel that you Google the term "Lensalign" and look into a piece of hardware that can save you a lot of headache/heartache in the world of microadjusting. I purchased this product about 2 years ago and have never regretted it. It's not as glamorous as some methods, but works quite well. Steve
JohnSheehy Goldmember 4,542 posts Likes: 1215 Joined Jan 2010 More info | Feb 01, 2015 08:44 | #15 guntoter wrote in post #17409281 I have been working with my Tammy 150-600 to try to make it take sharp pics on my 7DII. This is my latest effort. I don't think it is as sharp as I want it to be, but close. ![]() It's impossible to tell how sharp or well-focused your lens is from a picture of that size without more information. If the original at flickr is a 100% crop, and you're at 600/6.3, then that's pretty good, and you can get sharper results in the future at f/8 or even f/9 (above that, diffraction is counterproductive if you don't need the DOF). If it is a downsample from from 20MP to 2MP, then it is soft, but that can be due to processing as much as it is due to the lens. In any even, it is only barely soft as presented at about 2MP on flickr, and looks like it would sharpen very easily without adding significant noise.
| Latest registered member is semonsters 1052 guests, 103 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
