I've been looking at different combinations of strobe and softbox combinations used for portraits on Flicker and it seems some are warmer than others? Does the light modifier or post processing cause this warmness?
silvermesa1 Member 145 posts Likes: 17 Joined Aug 2013 Location: Columbia, Mo. USA More info | Feb 03, 2015 22:06 | #1 I've been looking at different combinations of strobe and softbox combinations used for portraits on Flicker and it seems some are warmer than others? Does the light modifier or post processing cause this warmness?
Echo63 Goldmember 2,868 posts Likes: 169 Joined Aug 2006 Location: Perth - Western Australia - Earth More info Post edited over 8 years ago by Echo63. | Feb 03, 2015 22:41 | #2 There will be a slight variation, brand to brand - and different flashes are slightly different colours (some change as the power is dialed up or down too) My Best Imageswww.echo63.deviantart.com
Feb 04, 2015 00:34 | #3 Some strobes also have some constant color light, while others dont which means there could be a greater variation in light color.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info Post edited over 8 years ago by Wilt. (2 edits in all) | Feb 04, 2015 00:47 | #4 And the 'white' polyester front panel will YELLOW WITH AGE...just like a cotton or blend white dress shirt in a closet, if hung there for years without laundering! You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
windpig Chopped liver More info | Feb 04, 2015 06:28 | #5 I'd say more than a little variation for sure between my Elinchrom, Fotodiox and Photoflex. Enough to not mix them for main and fill. Would you like to buy a vowel?
Feb 04, 2015 08:57 | #6 Still, I would submit that most of the noticeable variation is done in post. http://www.avidchick.com
photoperson Member 55 posts Likes: 5 Joined Oct 2009 More info | Feb 04, 2015 08:57 | #7 If you shoot raw, you can do a test to see how the color varies by shooting a target with neutral greys, like a Macbeth color checker, then use the eyedropper in the raw processing program to get the color temp of the neutral grey.
simonbarker Senior Member 253 posts Likes: 65 Joined Mar 2009 More info | Feb 04, 2015 17:44 | #8 Some brands can produce considerably different colour temperatures with the same light source, in an ideal world try to stick with the same brand.
| Latest registered member is Monkeytoes 1322 guests, 169 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
