FORUMS Forum FAQ and Information Forum Talk
Thread started 06 Feb 2015 (Friday) 06:08
Does MQ time out?
Picture ­ North ­ Carolina
Gaaaaa! DOH!! Oops!
Post edited over 8 years ago by Picture North Carolina.
Feb 06, 2015 06:08 |  #1
Here's what happened:
I played around with multi-quote to see how it worked. I selected a few, but never posted with them and moved on.
A few days later I went to reply in a different thread in a completely different forum and up popped the multi-quotes from days previous.
Better than having multi-quotes time out if not used, I think if a person selects MQs and does not use them, as soon as the user exits reading that thread, the MQs (selected) should disappear.
Website (external link) |
Jon
Joined Jun 2004
Feb 06, 2015 09:22 |  #2
People, and I'm one of them, will often use the MQ function to reply to someone in a different thread. My personal preference would be to have the AMASS 1.0 behavior where the MQs don't get placed into your reply automatically; you could choose to insert them individually as needed/wanted. However, the majority of users seem to have a preference for the MQs being automatically inserted in a reply, and Pekka's decision to make MQs available until used (or cleared) seems to be well-thought-out.
Jon
Cocker Spaniels
OhLook
Gallery: 105 photos
Joined Dec 2012
Feb 06, 2015 10:10 |  #3
Picture North Carolina wrote in post #17417996 (external link)
The same thing happened to me when I reported a different problem with MQ, except that days hadn't passed, only minutes. I think it was a temporary malfunction.
The quotes are intentionally made to persist if you use MQ in another thread, for the reason Jon gave.
PRONOUN ADVISORY: OhLook is a she. | Comments welcome
Progress toward a new forum being developed by POTN members:
https://photography-on-the.net …/showthread.php​?t=1531051
Gaaaaa! DOH!! Oops!
Feb 06, 2015 12:38 |  #4
Appreciate the replies. However, I disagree on the usefuleness of the present design.
As a test I went to another forum, grabbed 3 MQs, then came here to reply.
All three were quoted. Upon going to the Quote Tools, there was no option to clear quotes from present post. There is an option to clear multiquotes, but when you press it it does not clear the quotes already in the post. To do so, you either need to manually edit or cancel the post, press confirm to cancel, then click to reply again.
There should be an option in the Quote Tools box to "Clear Multi Quotes in Present Post". With that you can clear the quotes, then press the Clear Multi Quotes button to stop them from popping up in the future.
Jon
Joined Jun 2004
Feb 06, 2015 13:58 |  #5
Well, like I said, I preferred the AMASS 1.0 implementation, where you had to add the MQs to the post yourself.
Jon
Cocker Spaniels
Pekka
El General Moderator
Gallery: 36 photos
Best ofs: 7
Joined Mar 2001
Feb 06, 2015 18:33 |  #6
Picture North Carolina wrote in post #17418657 (external link)
The solution is simple:
To clear a post from automatically added MQ's: After you reply and MQ's are inserted press UNDO once (the green arrow left). Only one click of undo is needed.
You can also press CTRL+A (="select all") and then hit space.
The Forum Boss, El General Moderator
AMASS 2.5 Changelog (installed here now)
Pekka
Gallery: 36 photos
Best ofs: 7
Joined Mar 2001
Feb 06, 2015 18:37 |  #7
Jon wrote in post #17418776 (external link)
You can press undo once and then use the Quote Tools.
Should I add to settings "do not add MQ's automatically"? How frequent really is the case that you do NOT want to add them (you did pick them for that reason alone) and you do NOT want to reply to them in posting time order?
Jon
Joined Jun 2004
Feb 06, 2015 19:18 |  #8
Pekka wrote in post #17419221 (external link)
For me, a fair percentage of the times I use MQ (as distinct from "Quote") I don't want to use them in the sequence I picked them, but I'm probably not typical. If it's not a big programming deal, I wouldn't mind it, but there are certainly things that would be more generally useful to more people.
Jon
Cocker Spaniels
OhLook
Gallery: 105 photos
Joined Dec 2012
Feb 06, 2015 19:30 |  #9
Jon wrote in post #17419274 (external link)
If quotes are going to be inserted automatically into my reply, I'd like them to appear in the order in which they were posted, regardless of which one I picked first. The way 1.0 did it worked well for me, but some people needed help using that system. The way 1.1 does it works well enough. I don't see this variation as a big issue.
Bill ­ Boehme
Enjoy being spanked
Gallery: 39 photos
Feb 11, 2015 01:15 |  #10
Maybe Jon and I are the only ones, but when I am composing a post, I prefer to use MQ's as they best fit into the context of what I am writing about which rarely has anything to do with a timeline. It's only a minor inconvenience since I generally use a whole jar of paste shifting things around before I am finally done composing a post.
Atmospheric haze in images? Click for Tutorial to Reduce Atmospheric Haze with Photoshop.
Gear List .... Gallery: Woodturner Bill (external link)
Donate to Support POTN Operating Costs
2,417 views & 0 likes for this thread, 5 members have posted to it.
Does MQ time out?
1185 guests, 136 members online
