Thread started 07 Feb 2015 (Saturday) 15:20
Just got my 7D2
Nascar ­ Nut
Joined Feb 2004
Feb 07, 2015 15:20 |  #1
Ordered it from B&H Thursday night and had it here at my home in Iowa Friday afternoon with free shipping. You can't beat that. Now time to learn all the new settings. I am going to micro adjust my 100-400 using the dot tune method. Is this a pretty good method to use? Also what are your setting for BIF that you are getting good results with. Lots of eagles around here and the waterfowl will be coming through in another month or so. I would like to have a starting place for BIF to work with.
LJ3Jim
Joined Jan 2012
Feb 07, 2015 16:02 |  #2
With your handle, you should be headed to Daytona. :-)
Shoot with your lens for a while before doing mfa. If you consistently see front or back focus, then consider mfa. You probably won't need it.
For birds, I usually start with manual mode, 1/1000, f/5 (ish), Auto ISO, evaluative metering (sometimes spot), center point focusing, ai servo, focus case 1.
Image editing ok; C&C always welcome.
Nascar ­ Nut
Joined Feb 2004
Feb 07, 2015 16:36 |  #3
Your right I should be headed to Daytona. Would be a lot nicer weather there also then what it is here in Iowa. Thanks for the tips. I just did the dot tune and got 4 different results. I wonder if I need more light. I had the camera set to iso 100 at F5.6 and the shutter speed was 160. My four results were (0 or +1), (+3), (+2 or +3) and (-1)
rgs
Gallery: 176 photos
Feb 07, 2015 16:44 |  #4
I've used dot tune in the past but have read some reports of it being inconsistent. So now I just use an angled target inside for shorter lenses and an angled brick wall outside for longer lenses.
Canon 7d MkII, Canon 50D, Pentax 67, Canon 30D, Baker Custom 4x5, Canon EF 24-104mm f4, Canon EF 100mm f2.8 Macro, Canon EF-S 10-22mm f/3.5-4.5, 70-300mm f/4-5.6 Di VC
The Singular Image (external link)Richard Smith Photography (external link)
Richard Smith Real Estate Photography (external link)500PX (external link)
Fine Art America (external link)
Nascar ­ Nut
Joined Feb 2004
Post edited over 8 years ago by Nascar Nut. (3 edits in all)
Feb 07, 2015 16:56 |  #5
I just did four more and this time all 4 were 0 or +1 so I think I will just leave it at 0 and shoot awhile and see how it does. I noticed there are two different MFA adjustments on the camera. The top one didn't make any difference when adjusted and the bottom one did. My 7D just had one adjustment. I used the bottom one. I saw someone also posted a three book method. I will give your angled brick wall and this three book method a try just to see what the photos look like.
Archibald
You must be quackers!
Gallery: 789 photos
Feb 07, 2015 17:12 |  #6
rgs wrote in post #17420617 (external link)
Angled targets will front-focus because the AF point is bigger than you think, and it will focus on the nearest part.
MikeWa
Gallery: 89 photos
Joined Apr 2012
Feb 07, 2015 17:28 |  #7
Enjoy your new camera. The 7D-2 is a fantastic piece of equipment.
Mike
Mike...G9; 7D; 7D Mark II; EF-S 10-22mm; EF-S 18-135mm IS STM; EF 28-300mm F3.5-5.6L; EF 70-300mm IS USM; EF 70-200mm F2.8L IS-II; EF 100-400mm f4.5-5.6L IS; EXT 1.4-II & 2.0-III; The more I learn the less I know.
LJ3Jim
Joined Jan 2012
Feb 07, 2015 18:34 |  #8
Nascar Nut wrote in post #17420632 (external link)
The top one is for the 100mm end of your lens. The bottom one is for the 400mm end. Primes will have just one adjustment scale.
johnf3f
Feb 07, 2015 19:00 |  #9
I don't use a 7D2 but on my 1Dx (similar AF settings/cases) I use Manual mode, 1/1000 sec at F8 with Auto ISO. Partial metering, AF case 5 and single/single + 4 assist/single + 8 assist AF points depending on how accurately I can follow the bird.
This setup seems to work well for all my photography, I like to keep things simple!
Life is for living, cameras are to capture it (one day I will learn how!).
Nascar ­ Nut
Joined Feb 2004
Feb 07, 2015 21:56 |  #10
LJ3Jim wrote in post #17420728 (external link)
Thank you for clearing that up for me. I will have to do the 100 end too.
Nascar ­ Nut
Joined Feb 2004
Feb 07, 2015 21:59 |  #11
johnf3f wrote in post #17420763 (external link)
Thank you for sharing your settings. I am ready to dig into this camera and see what it can do.
MakisM1
Gallery: 50 photos
Joined Dec 2011
Post edited over 8 years ago by MakisM1. (2 edits in all)
Feb 08, 2015 09:14 |  #12
Archibald wrote in post #17420640 (external link)
The target is square on the lens axis, the scale for DOF is angled:
IMAGE: http://i37.photobucket.com/albums/e66/MakisM/Canon/Lens%20Tests/IMG_7861g1024_zps6ef30929.jpg~original
IMAGE LINK: http://s37.photobucket​.com …1024_zps6ef3092​9.jpg.html  (external link)
You can download the target and instructions from here (free):
http://www.peleng8.com …k-focus.html#.VNd91zUS1z​0 (external link)
Gerry
rgs
Gallery: 176 photos
Feb 08, 2015 14:40 |  #13
MakisM1 wrote in post #17421578 (external link)
This is very much like the target I use. Maybe the "angled scale" is not a good description. I only used the "angled brick wall" for my 70-300 because I didn't have enough room inside. And it did, indeed, front focus a bit and need an additional adjustment.
Nascar ­ Nut
Joined Feb 2004
Feb 09, 2015 16:02 |  #14
I think I will give this a try just to compare results with the dottune method
MakisM1
Gallery: 50 photos
Joined Dec 2011
Feb 09, 2015 17:43 |  #15
Nascar Nut wrote in post #17424135 (external link)
Heck! It's free!...:-D
Print it on normal paper, but the glue it on cardboard, so it retains the desired shape. Let us know of the results!
Gerry
5,021 views & 0 likes for this thread, 7 members have posted to it.
Just got my 7D2
1039 guests, 107 members online
