Why not go with an ef mount, automatically they would have tons of lenses, not have to engineer a new mount and new lenses. And size wise its not that much bigger.
burb1972 Member 126 posts Joined Aug 2013 More info | Feb 07, 2015 17:03 | #1 Why not go with an ef mount, automatically they would have tons of lenses, not have to engineer a new mount and new lenses. And size wise its not that much bigger. mike parker
Feb 07, 2015 17:22 | #2 burb1972 wrote in post #17420635 Why not go with an ef mount, automatically they would have tons of lenses And that's possibly one of the core reasons. Tools of the trade: Canon 400D, Canon 7D, Canon 70-200mm f2.8 IS L M2, Sigma 120-300mm f2.8 OS, Canon MPE 65mm f2.8 macro, Sigma 150mm f2.8 macro, Tamron 24-70mm f2.4, Sigma 70mm f2.8 macro, Sigma 8-16mm f4.5-5.6, Raynox DCR 250, loads of teleconverters and a flashy thingy too
Feb 07, 2015 17:45 | #3 the sl1 is slightly thicker. it just seems it would be a much better system if it was an ef mount given the limited amount of eosm lenses. once you add the adaptor its almost as big as a sl1. And if it was a better system, would canon care if it sold a t3i vs 2 eosm's.? I think a really good eosm would sell better than a T3i(viewfinder vs size, size would win in sales). It seems if it was smaller than an dslr and better than the competition( due to lens selection) it would be a gateway camera, leading more people to get stuck with canon.Plus now the ff cameras are coming down in price. I got my cherry 5dc for 500$ over a year ago. However, very valid points on previous post. mike parker
sebr Goldmember 4,628 posts Likes: 9 Joined Jan 2007 Location: Sweden/France More info | Feb 07, 2015 18:23 | #4 The smaller mount also allows having smaller lenses, making the all package much smaller than regular DSLRs. Sebastien
Feb 07, 2015 19:05 | #5 Canon makes an ef/efs adapter as well. Pretty cheap too. _______________
Petie53 Senior Member 373 posts Likes: 96 Joined Jan 2014 More info | Feb 07, 2015 19:22 | #6 I have both the M and some EF series cameras. As I understand it - could be wrong - as the M has no mirror, the lens can be designed with the rear element at about the same position as the rear connector as no room needs to be provided to clear the mirror movement and the mount itself is much closer to the sensor. The EF and EF-S lenses are designed to allow the image to correctly hit the sensor with additional clearance to clear the mirror. This is why the M to EF adapter is used to give the required spacing that M lenses don't need. Pete
BigAl007 Cream of the Crop 8,120 posts Gallery: 556 photos Best ofs: 1 Likes: 1682 Joined Dec 2010 Location: Repps cum Bastwick, Gt Yarmouth, Norfolk, UK. More info | Feb 07, 2015 20:13 | #7 As others have said it is much easier to make small light short focal length lenses when you have a smaller flange to sensor distance. This is because you do not need to make the lens design retrofocus, which tends to make for bigger lenses. Thats before you allow for EF lenses that have to accommodate a 35×24mm image circle coverage. So your mirrorless with standard and wide lenses will be much smaller. This is also the same for traditional 35mm rangefinder cameras though. Just look at the size of say a 35mm lens for Leica compared to a 35mm for any SLR. I have a 35mm Olympus XA2 with a 35mm f/4 (I think) fixed lens, and the whole thing is the size of a 20 pack of cigarettes. It's a pretty tiny front element too considering, just because it can be close to the film plane.
MalVeauX "Looks rough and well used" More info Post edited over 8 years ago by MalVeauX. | Feb 08, 2015 15:23 | #8 burb1972 wrote in post #17420635 Why not go with an ef mount, automatically they would have tons of lenses, not have to engineer a new mount and new lenses. And size wise its not that much bigger. Heya,
Feb 08, 2015 20:29 | #9 burb1972 wrote in post #17420675 the sl1 is slightly thicker. it just seems it would be a much better system if it was an ef mount given the limited amount of eosm lenses. once you add the adaptor its almost as big as a sl1. And if it was a better system, would canon care if it sold a t3i vs 2 eosm's.? I think a really good eosm would sell better than a T3i(viewfinder vs size, size would win in sales). It seems if it was smaller than an dslr and better than the competition( due to lens selection) it would be a gateway camera, leading more people to get stuck with canon.Plus now the ff cameras are coming down in price. I got my cherry 5dc for 500$ over a year ago. However, very valid points on previous post. That, ultimately, is why I got an SL1. With the M, you're stuck with a handful (even worse here in the US) of lenses, and if you "jut add the adapter", you might as well have the SL1, with its faster AF and the satisfying *chunk* of a shutter. https://www.flickr.com/photos/127590681@N03/
BigAl007 Cream of the Crop 8,120 posts Gallery: 556 photos Best ofs: 1 Likes: 1682 Joined Dec 2010 Location: Repps cum Bastwick, Gt Yarmouth, Norfolk, UK. More info | Feb 09, 2015 04:58 | #10 LonelyBoy wrote in post #17422733 That, ultimately, is why I got an SL1. With the M, you're stuck with a handful (even worse here in the US) of lenses, and if you "jut add the adapter", you might as well have the SL1, with its faster AF and the satisfying *chunk* of a shutter. But that satisfying clunk is not the shutter it is the mirror. Most of the mirrorless bodies still have a mechanical focal plain shutter for still exposures, as they work better. So they have to close the shutter, flush the charge from the sensor then expose. The same happens for stills on a DSLR when using LV.
Feb 09, 2015 06:46 | #11 BigAl007 wrote in post #17423212 But that satisfying clunk is not the shutter it is the mirror. Most of the mirrorless bodies still have a mechanical focal plain shutter for still exposures, as they work better. So they have to close the shutter, flush the charge from the sensor then expose. The same happens for stills on a DSLR when using LV. Alan Right, my bad. My hands are way too shaky for LV, so I never use it anyway (which is another part of SL1 over M for me). https://www.flickr.com/photos/127590681@N03/
Feb 09, 2015 08:10 | #12 Thanks for all the great and informative replies. mike parker
burb1972 THREAD STARTER Member 126 posts Joined Aug 2013 More info Post edited over 8 years ago by burb1972. | Feb 09, 2015 08:17 | #13 http://en.m.wikipedia.org/wiki/Flange_focal_distance mike parker
mclaren777 Goldmember 1,482 posts Likes: 86 Joined May 2012 Location: Olympia, WA More info | Feb 09, 2015 09:16 | #14 It bums me out that Canon will probably never make something like the Sony RX1. A simple comparison of sensor technology: Nikon vs. Canon
msowsun "approx 8mm" More info | Feb 09, 2015 10:09 | #15 mclaren777 wrote in post #17423433 It bums me out that Canon will probably never make something like the Sony RX1. I just want Canon to make a small, full-frame camera with the 6D's sensor. The Sony RX-1 is about $2,800 and is not without flaws. MaybeCanon could do a little better if they ever try to make something similar. Cons Autofocus speed not fast enough for moving subjects Autofocus struggles in low light Significant vignetting (as with similar lenses), corrections 'baked into' Raw files Multiple button presses required to move AF point No built-in viewfinder (and accessory options rather expensive) No focus guides for video shooters Disappointing video quality even when in focus Focus peaking in un-magnified live view would have been a major benefit Rear shoulder dial makes it less engaging to shoot in shutter-priority mode Can't shoot X.Fine JPEG and Raw No option to re-process Raw in camera Lack of included charger makes it harder to keep a spare battery charged The standard Sony Alpha function screen seems simplistic and inappropriate for this camera Laggy to engage magnified image review Awkward separation of movie and stills in playback Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
| Latest registered member is semonsters 1505 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
