Thread started 09 Feb 2015 (Monday) 01:22
Alien Bees Flash Sync
fashionrider
Joined Dec 2011
Feb 09, 2015 01:22 |  #1
I have 4 alien bees and enough triggers to attach to each light and on camera. I was wondering, in the event my triggers broke or something, are there any disadvantages to using the alien bees' flash sensor sync? I would have a trigger on my camera, and another trigger on a light. The rest of the lights will be on optical slave.
One disadvantage I can think of is if there are other sources of flash in the area, they would trigger my lights accidentally. However, I'm in a studio by myself so that's not a problem usually. Any other problems? Does the flash sync speed have to be reduced to allow more time for the optical sensors to react to the flash?
Gear List (5D3, 70-200 f2.8L IS II, Sigma 85mm f1.4, Sigma 35mm f1.4, 50 f1.8, 24-105L, Alien Bee lights, etc etc)
SkipD
Joined Dec 2002
Feb 09, 2015 04:44 |  #2
In an indoor environment you should have no problems using the optical slaves unless for some reason the light from the "master" unit cannot reach the slave sensors in the other units. Outdoors, getting the optical slaves to function can be quite tricky.
You probably won't have to reduce your shutter speed to make the optical slaves function properly.
Skip Douglas
dmward
Gallery: 29 photos
Feb 09, 2015 08:00 |  #3
The only time I had trouble with the optical trigger was when one light was too close to a window and the ambient overpowered the triggering flash.
In a studio it will work fine. Never had a problem with sync either.
fashionrider
Joined Dec 2011
Feb 10, 2015 17:01 |  #4
SkipD wrote in post #17423199 (external link)
dmward wrote in post #17423331 (external link)
Thanks guys! Really helped a lot!
1,347 views & 0 likes for this thread, 3 members have posted to it.
864 guests, 163 members online
