With more than one photo.
Feb 09, 2015 09:05 | #1 With more than one photo. Image hosted by forum (712089) © DigitalDon [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Image hosted by forum (712090) © DigitalDon [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff.
Feb 09, 2015 09:06 | #2 Next Image hosted by forum (712091) © DigitalDon [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Image hosted by forum (712092) © DigitalDon [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff.
Feb 09, 2015 09:07 | #3 The end Image hosted by forum (712095) © DigitalDon [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff.
dkizzle Goldmember 1,184 posts Likes: 35 Joined Mar 2012 More info | Feb 09, 2015 09:21 | #4 I do not see a story, I only see pictures from the same location but there is no apparent translation from scene to scene. I want to guest blog on your Landscape / Travel photography blog, PM for details
Feb 09, 2015 10:46 | #5 dkizzle wrote in post #17423439 I do not see a story, I only see pictures from the same location but there is no apparent translation from scene to scene. Hi dkizzle
Feb 09, 2015 22:36 | #6 Some thoughts ... A bunch of stuff.
Feb 09, 2015 23:05 | #7 I suspect it was the swan. Canon MarkII 5D * Canon 70-200mm f/4L * Canon 17-40mm f/4L * Canon TS-E 24mm f/3.5L II * Canon 50mm f/1.8 * Venus 60mm f/2.8 2x Ultra Macro
Feb 10, 2015 09:26 | #8 dogface wrote in post #17424716 Some thoughts ... Pics 3-5 have something obvious in common as they are taken from the same direction (downstream) getting closer to the end. Pics 1-2 look to be upstream from where pic 3 was taken and hence a discontinuity with no clear connection. The "end" itself doesn't seem to be the end since there is a larger lake behind it. The larger lake itself would seem to be the natural end for the sequence in 3-5. The road in pic 3 interrupts the story you're trying to tell. Perhaps starting off from pic 3 (leaving out the road) and ending up at the larger lake would be a clearer story. To call it a "story" requires more than just water running downhill. I think there needs to be something in common floating downstream in each photo as the subject of the story. Perhaps you can get a duck to cooperate - preferably one with ducklings. Get momma taking the ducklings downstream to the larger lake. Of course, if you could do that, "Journey" would probably be a better title. Thanks dogface, I think I was riding my horse facing it's back side, I should have started at the big lake facing the small water fall, but I would have to climb a tree to get the upper pond that drains into the lake in pic 5, If I could do this, then I could have moved to the location in pic3 and took a picture of the pond and water fall in pic 2. The reason I showed the road in 3 was to tell that the pond run under the road to connect pic 2 to pic 4 together.
Feb 10, 2015 09:29 | #9 EKOEPP wrote in post #17424767 I suspect it was the swan. It was
| Latest registered member is semonsters 1047 guests, 105 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
