Thread started 09 Feb 2015 (Monday) 14:06
7D II Customizing AF Selections
guntoter
Feb 09, 2015 14:06 |  #1
I have been watching several videos and following other instruction sites, and I can not find out if the 7D2 will do what I have in mind.
Here is what I want, and perhaps someone can tell me if the camera will do it, and if so, how to set it up:
When I use the shutter button I want the camera to focus one shot and case 1 and hold focus while I recompose or just take the shot.
At the same time, I want the back button AF-0n to be AI-servo and switch to Case 2.
This would have been perfect a few nights ago at a BBgame. I was taking the action on the court, but also my niece was a cheerleader on the side. Front button for her to focus on her and recompose, and back button for the court action.
It would even be nice if the front button was center focus only, and the back button was Center with expansion, but that might be asking for too much.
Can do?
Joel
GEAR
apersson850
Obviously it's a good thing
Gallery: 35 photos
Feb 09, 2015 14:53 |  #2
Yes, more or less. First you have to rethink, since the cases have no effect in One shot AF.
Anders
Nick5
Post edited over 8 years ago by Nick5. (2 edits in all)
Feb 09, 2015 14:56 |  #3
While the AF ON Button is active from the factory, if you want to use the AF ON Button for focus, you should remove AF from the Shutter. Otherwise you will refocus again.
I have been using Back Button AF for several years now.
Canon 5D Mark III (x2), BG-E11 Grips, Canon Lenses 16-35 f/4 L IS, 17-40 f/4 L, 24-70 f/4 L IS, 70-200 f/2.8 L IS II, 70-200 f/4 L IS, 70-200 f/4 L IS Version II, 100-400 f/4.5-5.6 L IS Version II, TS-E 24 f/3.5 L II, 100 f/2.8 L Macro IS, 10-22 f3.5-4.5, 17-55 f/2.8 L IS, 85 f/1.8, Canon 1.4 Extender III, 5 Canon 600 EX-RT, 2 Canon ST-E3 Transmitters, Canon PRO-300 Printer
jessandjamie
Joined Jun 2011
Feb 09, 2015 15:04 |  #4
You can assign one case to the AF-ON button and the second case to the * button.
Diver-Down
Feb 09, 2015 15:43 |  #5
Yup can do but I'm almost certain you can't use the shutter button for focusing at that point, you'll have to use 2 back buttons. I just set mine up like this and think it's gonna work out great.
I have the (AF ON) button set to AIServo and to maintain what ever focus points and case # are set and the (*) button to one shot and center point only.
Go to the custom controls: set the shutter button to (metering start) Select the AF-ON button set it to (metering and AF start) then hit the INFO button and go through the parameters to associate the AF-ON button with. Then go to the (*) button and set up the parameters there as well.
guntoter
Feb 09, 2015 17:52 |  #6
Thank you for the answers guys. I will try to set those things up.
Joel
GEAR
djsander
Joined Mar 2012
Feb 09, 2015 18:38 as a reply to  @ guntoter's post |  #7
With the 7dii you can leave the shutter button for start metering and one shot focus. Then go in the custom menu and you can set the af on and * for start metering and have each selected for a different Ai servo case. You can do a multitude of other customizations including which focus points to use or manually set. I have my 7d2 set up like this so I can switch from one shot to AI servo with out having to change any settings. I'm still tinkering and learning. there are a lot of different ways to set up different buttons. Good luck.
guntoter
Post edited over 8 years ago by guntoter.
Feb 10, 2015 10:14 as a reply to  @ djsander's post |  #8
Thank you djsanders for the advice. Haven't had a chance to try any options yet, but soon.
Joel
GEAR
Nascar ­ Nut
Joined Feb 2004
Feb 10, 2015 16:35 |  #9
Diver-Down wrote in post #17424104 (external link)
I like this setup but can you also have it set shutter speed and aperture
guntoter
Feb 10, 2015 19:13 |  #10
Wow, this camera is more fantastic than I knew.
AF-ON button = AI-Servo, Center + 8 Surrounding points, Case 2
* button = One Shot, Expanded Center, Case 1
Front button = One shot, Center Focus, Case 1
Still checking into more that it will do, but that setup is sweet.
Joel
GEAR
apersson850
Gallery: 35 photos
Feb 11, 2015 05:04 |  #11
guntoter wrote in post #17426082 (external link)
OK, once again, then. The different AF cases have no effect whatsoever when you use One Shot AF.
Anders
guntoter
Feb 11, 2015 07:29 |  #12
apersson850 wrote in post #17426695 (external link)
Hmmmm. Ok. Thanks.
Obviously, I am still learning this camera, and loving it.
Joel
GEAR
rgs
Gallery: 176 photos
Feb 11, 2015 08:20 |  #13
Check the DOF preview button. You can program it to toggle between one shot and AI Servo when you hold it down. Put your camera in servo with whatever case you want and hold down the DOF preview button when you want to change to one shot. Case doesn't matter with one shot. You can do the same thing with the * but the DOF preview may be more convenient and not as easily confused with the AF-ON button.
Also, if you find you don't want those setting all the time but find them extensively useful under some conditions, you can set it up and then save it as one of your custom mode settings. Then it's out of the way until you need it.
Canon 7d MkII, Canon 50D, Pentax 67, Canon 30D, Baker Custom 4x5, Canon EF 24-104mm f4, Canon EF 100mm f2.8 Macro, Canon EF-S 10-22mm f/3.5-4.5, 70-300mm f/4-5.6 Di VC
The Singular Image (external link)Richard Smith Photography (external link)
Richard Smith Real Estate Photography (external link)500PX (external link)
Fine Art America (external link)
guntoter
Feb 11, 2015 08:22 |  #14
rgs, Thanks for the advice.
Joel
GEAR
3,358 views & 0 likes for this thread, 8 members have posted to it and it is followed by 6 members.
1052 guests, 103 members online
