I currently use PSE 12 and am wanting to give LR a shot. I haven't had good luck with the Photomerge exposure but have seen and heard good things about LR and the plug-in. Aside from purchasing Lightroom, what else would I need?
Feb 09, 2015 14:14 | #1 I currently use PSE 12 and am wanting to give LR a shot. I haven't had good luck with the Photomerge exposure but have seen and heard good things about LR and the plug-in. Aside from purchasing Lightroom, what else would I need? 6D | 5D4 | 24-105 f4L | Sigma 50 2.8 Macro | 17-40 f4L| 135 f2L | 70-200 f2.8L ii | Sigma 35 1.4 Art | Canon 24-70 ii
rgs Goldmember More info Post edited over 8 years ago by rgs. (2 edits in all) | Feb 09, 2015 14:28 | #2 You need LigthRoom and LR Enfuse. LR Enfuse is donation-ware - you will need to make a small donation to get it to work correctly but you can try it out first. I think there is a free utility you also need to install but all that is on the LR Enfuse website. Canon 7d MkII, Canon 50D, Pentax 67, Canon 30D, Baker Custom 4x5, Canon EF 24-104mm f4, Canon EF 100mm f2.8 Macro, Canon EF-S 10-22mm f/3.5-4.5, 70-300mm f/4-5.6 Di VC
That's what I have heard. I have not used HDR on my real estate stuff and don't intend to. Is it possible that me and someone that has a copy of LR could exchange codes and I be able to use LR and they be able to use PSE 12? That may be a stupid question. 6D | 5D4 | 24-105 f4L | Sigma 50 2.8 Macro | 17-40 f4L| 135 f2L | 70-200 f2.8L ii | Sigma 35 1.4 Art | Canon 24-70 ii
Feb 09, 2015 14:52 | #4 I don't think you can exchange codes. Here's a LR Enfuse shot. I expose for the density I want in the windows and then run an additional 6 shots with each one 1 stop (SS, not aperture) lighter than the last (0,+,++,+++, ect). Then, after importing into LR, I decide how many of the lighter brackets to use, run enfuse, and then tweak in LR as needed. Work very well. Image hosted by forum (712132) © rgs [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Canon 7d MkII, Canon 50D, Pentax 67, Canon 30D, Baker Custom 4x5, Canon EF 24-104mm f4, Canon EF 100mm f2.8 Macro, Canon EF-S 10-22mm f/3.5-4.5, 70-300mm f/4-5.6 Di VC
Feb 09, 2015 15:18 | #5 You might check out Machinery2. Its an hdr program that can also do regular photo editing. Also it can do hdr from 1 photo. You can do hdr that is so natural that some wouldnt notice. I dont do much hdr but for sharpening its hard to beat. Dave
Feb 09, 2015 15:50 | #6 Here are 2 that I just edited in about 2 minutes each. I believe Machinery2 may be an awesome tool in the future. I will have to practice more so I can make it look a little less HDR but I believe it is going to be my new go to editing tool for real estate. I should add that this was shot with a 7D and the new 10-18 lens. No flash, just natural light. I haven't mastered the off camera flash just yet. The second was edited in Machinery2... IMAGE LINK: https://flic.kr/p/qQnKTi Like I said, I believe the 2nd may be a little too HDR like but it seems very easy to make it look more natural. Thanks for the tip! 6D | 5D4 | 24-105 f4L | Sigma 50 2.8 Macro | 17-40 f4L| 135 f2L | 70-200 f2.8L ii | Sigma 35 1.4 Art | Canon 24-70 ii
Glad to be of help! I havent used it much but for one shot you can use bracketing, +2/-2 and then use the natural effect in the presets. Works really well for me and I can't believe how fast it is! Dave
Feb 09, 2015 16:06 | #8 I forgot, its also a plugin for Lightroom, but I havent set that up yet. Dave
rgs Goldmember More info Post edited over 8 years ago by rgs. | Feb 09, 2015 16:21 | #9 No 1. Looks a good but a little dark and a little flat. How did you pull that door? Did you blend some images? If so you did a good job of it. I would want it to be a bit brighter and lighter (the adage is light and bright sells). You could do that by making the whole thing lighter (except maybe the door - do you have layers so you can make the room lighter without changing the window?) and then boosting, clarity (increases midtone contrast) and/or vibrance (increases midtone saturation). Saturation and contrast are too blunt of tools. You could also increase blacks or shadows SLIGHTLY which would broaden the overall tonal range pulling down the lighter tones. Canon 7d MkII, Canon 50D, Pentax 67, Canon 30D, Baker Custom 4x5, Canon EF 24-104mm f4, Canon EF 100mm f2.8 Macro, Canon EF-S 10-22mm f/3.5-4.5, 70-300mm f/4-5.6 Di VC
Feb 09, 2015 16:29 | #10 One other little nicety. Look at the lights in the fan. See how they glare? Look at some lights in around you. You can't usually see the filament but you can usually see detail. If you use enough darker brackets (or balance flash well enough if you prefer that method) you can get a little detail in the light bulbs or shades and it look more natural. This is why my bracket routine is to start either at the outside exposure or 1 stop under and then to open up 1 stop at a time for 6 additional brackets. I don't necessarily use them all but I do have them if needed. Canon 7d MkII, Canon 50D, Pentax 67, Canon 30D, Baker Custom 4x5, Canon EF 24-104mm f4, Canon EF 100mm f2.8 Macro, Canon EF-S 10-22mm f/3.5-4.5, 70-300mm f/4-5.6 Di VC
I ALWAYS welcome opinions. These were both done in about 2 minutes. I can't stand HDR myself. I'm still learning layering and being able to raise shadows and brightness without adding too much noise. I try to keep my editing to a minimum so I can keep the realistic look as much as possible. Thanks for your comments and I welcome all of them. 6D | 5D4 | 24-105 f4L | Sigma 50 2.8 Macro | 17-40 f4L| 135 f2L | 70-200 f2.8L ii | Sigma 35 1.4 Art | Canon 24-70 ii
Feb 09, 2015 17:06 | #12 No HDR was used on this one! 6D | 5D4 | 24-105 f4L | Sigma 50 2.8 Macro | 17-40 f4L| 135 f2L | 70-200 f2.8L ii | Sigma 35 1.4 Art | Canon 24-70 ii
Feb 10, 2015 08:36 | #13 rgs wrote in post #17424167 No 1. Looks a good but a little dark and a little flat. How did you pull that door? Did you blend some images? If so you did a good job of it. I would want it to be a bit brighter and lighter (the adage is light and bright sells). You could do that by making the whole thing lighter (except maybe the door - do you have layers so you can make the room lighter without changing the window?) and then boosting, clarity (increases midtone contrast) and/or vibrance (increases midtone saturation). Saturation and contrast are too blunt of tools. You could also increase blacks or shadows SLIGHTLY which would broaden the overall tonal range pulling down the lighter tones. No 2. Sorry - this one screams HDR to me - especially around the fan. And I know from experience that many agents and brokers don't like or are tired of HDR. They don't always know what it is but they don't like the look. They want the most appealing natural look they can get. The outside view in the doors is too light. HDR also tends to accentuate lines where darks and lights meet which sometimes makes it look a bit too much like an illustration rather than a photograph. I hope you won't take these comments as being negative - they were intended to be instructive and if I missed that target, I'm very sorry. I'm also pretty sure that 90% of agent's/brokers don't even know what HDR is. Sony A7ii [Sony FE 16-35mm f/4] [Sony FE 28-70mm] [Rokinon 135mm F2] [Sony 50mm 1.8]
Feb 10, 2015 10:20 | #14 njstacker22 wrote in post #17425194 I'm also pretty sure that 90% of agent's/brokers don't even know what HDR is. First, I would not underestimate the photographic sophistication of many real estate professionals. Many new phones have an (sort of) HDR function and some new DSLRs will do HDR in camera. I would not assume that many have at least a cursory knowledge of HDR. Canon 7d MkII, Canon 50D, Pentax 67, Canon 30D, Baker Custom 4x5, Canon EF 24-104mm f4, Canon EF 100mm f2.8 Macro, Canon EF-S 10-22mm f/3.5-4.5, 70-300mm f/4-5.6 Di VC
Feb 11, 2015 19:28 | #15 Question regarding machinery2.....I'm still using the demo mode because 1) I'm not sure the full version has anything more than what I use in the demo mode and 2) I can't figure out how to read the price as its not in American dollars. My question is why does it sometimes let me preview the .cr2 before i actually import and open it and other times it won't let me preview it unless I import and open. 6D | 5D4 | 24-105 f4L | Sigma 50 2.8 Macro | 17-40 f4L| 135 f2L | 70-200 f2.8L ii | Sigma 35 1.4 Art | Canon 24-70 ii
| Latest registered member is semonsters 940 guests, 109 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
