Thank you all for commenting
I'll have to spend some time experimenting with the advices you all have given me.
nqjudo wrote in post #17426563
The best option I found was to use soft focus M42 adapted lenses.
I didn't know anything about these lenses before but seems like it could be a good alternative.
flowrider wrote in post #17426573
Back in the day I used hair spray on an old UV filter which worked pretty well. My favourite way to get soft focus was using a Zeiss Softar filter.
That filter looks good, just saw some photos with it on flickr but unfortunately there are just a few of them, thanks for the link.
ZoneV wrote in post #17426754
I use dedicated lenses.
Sometimes the softness is side effect, sometimes I would be happy the lens would give the same bokeh without softness in the sharp area. But often I like this softer effect - not completely blurred, but some spherical abberation - glow.
But I am sure that I do not want to make such in Photoshop - I would spend too much time, and would fail.
Those are really nice photos, especially #1 and #2.
PhotosGuy wrote in post #17426915
If I could only pick one, it would be the "Grease Job". Advantage is that you can apply the effect selectively & have it just where you want it.
Nice image.
Applying the effect selectively would definitively be a great advantage.
nathancarter wrote in post #17427044
What sort of look are you going for?
I did some 80's-style Glamour Shots a couple years ago, and after fumbling around with a few different methods, I decided that I liked the Clarity slider in Lightroom/ACR the best.
I've tried playing with clarity but so far haven't achieve a result I like, maybe with other kind of photos.
groundloop wrote in post #17427125
For a photoshop solution I'd imagine Field Blur would work better than just Gaussian Blur. You can 'pin' an area on the photo, define how much blur to apply, and transition to a different amount of blur in a different area of the photo.
nathancarter wrote in post #17427188
Surface Blur is probably also worth checking out. Again, depending on the nature of the subject matter, and the desired end result.
Interesting ideas, I haven't tried with different types of blur, but it's worth trying.
jimeuph1 wrote in post #17427196
Instead of putting Vaseline or whatever on the actual lens....
Buy a cheap clear filter and put the Vaseline on the filter!
Much easier to clean afterwards, with no real risk of damaging the lens!
I have a cheap UV filter I could use
Wilt wrote in post #17427260
One should understand that the different techniques of achieving soft focus are all
different in what they do, and about whether or not they please the VIEWER!
Classically, you can put a
- Softar filter over the lens
- a dark fine net over the lens
- a dark open net over the lens
- a white fine net over the lens
- a white open net over the lens
- a flesh colored fine net over the lens
- a flesh colored open net over the lens
- Vaseline on filter in front of the lens
- a dark fine net over the enlarger lens
- a dark open net over the enlarger lens
- a white fine net over the enlarger lens
- a white open net over the enlarger lens
- a flesh colored fine net over the enlarger lens
- a flesh colored open net over the enlarger lens
- or use a soft focus lens
...and now you can add different types of blur digitally
I know that putting a net over the taking lens is different in appearance from same net over the enlarger lens. Whether or not with digital blur one truly reproduces and of the analog approaches I have never bothered to investigate. I rather doubt it.
I also think that it is impossible (or at least impossible to me given my current photoshop skills) to reproduce those analog effects.
I guess I'll have to experiment to better know which technique I like best. I guess I'll have to start with spray, vaseline and nets, after that, filters and finally lenses.
