C & C pls
Feb 13, 2015 12:02 | #1 C & C pls Image hosted by forum (712781) © JPB the elder [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff.
Feb 13, 2015 12:47 | #2 Exposure looks fine, DOF is good but I'm not sure what there is to like about the shot. Technically it's OK. I don't see anything of interest in the frame at all.
Feb 13, 2015 13:05 | #3 James33 wrote in post #17430407 Exposure looks fine, DOF is good but I'm not sure what there is to like about the shot. Technically it's OK. I don't see anything of interest in the frame at all.
http://www.avidchick.com
Feb 13, 2015 15:15 | #4 A little background . This is roof on the waterwheel at Berry College in Rome Georgia . The green oxidized straps were added where stone shingles had been repaired and replaced . They copper straps were nailed to the roof with copper nails . Old construction and old buildings intrigue me .
LeftHandedBrisket Combating camera shame since 1977... More info Post edited over 8 years ago by Left Handed Brisket. | Feb 13, 2015 17:06 | #5 i'd say that this pic falls somewhere into the technical and/or abstract genre. PSA: The above post may contain sarcasm, reply at your own risk | Not in gear database: Auto Sears 50mm 2.0 / 3x CL-360, Nikon SB-28, SunPak auto 322 D, Minolta 20
Could this be done by cropping ? It is actually one that didn't make it to my blog . I am ,hopefully learning . Thanks
LeftHandedBrisket Combating camera shame since 1977... More info | Absolutely. If this is the full image, cropping might be tight, or might not work. If you look at the chimney it doesn't look exactly straight. I'm of the opinion things need to be exactly straight or off enough that it's obvios you didn't want it straight. I think as it is it qualifies for off just enough. PSA: The above post may contain sarcasm, reply at your own risk | Not in gear database: Auto Sears 50mm 2.0 / 3x CL-360, Nikon SB-28, SunPak auto 322 D, Minolta 20
LeftHandedBrisket Combating camera shame since 1977... More info Post edited over 8 years ago by Left Handed Brisket. (2 edits in all) | Feb 14, 2015 06:15 | #8 hope you don't mind, but i took the liberty of doing a crop while my coffee dripped this morning. This is straightening up the chimney a bit, notice also the trees. They are leaning a bit, notice on the right they lean to the left and on the left they lean to the right. Same with the sides of the chimney. This is a natural keystone effect that happens unless the camera is perfectly level. Just something to keep in mind as you crop pictures. Image hosted by forum (712884) © Left Handed Brisket [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. PSA: The above post may contain sarcasm, reply at your own risk | Not in gear database: Auto Sears 50mm 2.0 / 3x CL-360, Nikon SB-28, SunPak auto 322 D, Minolta 20
Thanks for the help . That little change does make quite the difference . I haven't got the computer skills down yet .
| Latest registered member is semonsters 1045 guests, 103 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
