Thread started 14 Feb 2015 (Saturday) 15:29
Spyder4Elite, Dell U2715H and RGB %
gnome ­ chompski
Joined Jun 2013
Feb 14, 2015 15:29 |  #1
I use a retina MBP 15" laptop for all post processing and computing needs. When I calibrate the retina screen, I get above 90%of the RGB spectrum. At least thats what I think it is. I just added the Dell monitor in the title and calibrated. The first calibration yielded like 90% RGB, but it was too bright. I adjusted the brightness, as well as the ambient light and re-calibrated. The profile it generated is only 85% RGB. Now, I have done minimal research into this, but is that a decent %? I feel like something is off but I really dont know where to start.
Tumblr (external link)
Instagram (external link)
battletone
Joined Sep 2009
Feb 19, 2015 00:07 |  #2
gnome chompski wrote in post #17431828 (external link)
I have been wondering the same thing.
I just bought an Apple Thunderbolt Display and used a Spyder4Pro and got 100% of sRGB and 85% of AdobeRGB. Seems the greens and into a little blue is where it was lacking on the color chart.
Cameras: 5D Mark IV, EOS 3, Elan 7
Lenses:15mm 2.8 fisheye, 16-35mm 2.8L II, 24-70mm 2.8L II, 85mm 1.8, 100mm 2.8L, 70-200L II IS
Tripod: Gitzo GT2531, Arca-Swiss Z1, RRS PC-LR
Lights: Photogenic PL1250 x2, 1500SL x1, Canon 580ex, YN 568ex II
Nogo
POTN record for # of posts during "Permanent Ban"
Gallery: 17 photos
Joined Dec 2013
Feb 19, 2015 00:18 |  #3
You should be able to get 100% or very close to 100% sRGB with a good quality monitor.
If you want to get close to 100% aRGB or ProPhoto RGB you have to spend the money and get a wide gamut monitor. Most photo labs only require sRGB so if you aren't a nut like some of us (me) there is no reason to spend the money it takes to handle aRBG.
B&H lists the monitor you purchased as 99% sRGB. That is fine for most advanced amateurs and probably most professional photographers. Unless your printer handles aRGB there is no real reason for your monitor to.
Philip
Aswald
Joined Oct 2013
Feb 19, 2015 00:53 |  #4
I use Dell's 2408WFP. U2410, U2711 and UP2414Q. Except for the 2408WFP, all others achieve 100%.
It usually calibrates more accurately in a completely dark room for me.
gnome ­ chompski
Joined Jun 2013
Feb 19, 2015 11:25 |  #5
Nogo wrote in post #17438634 (external link)
so am I doing something wrong as I am only getting 85-90% after calibration? I realize this might be nitpicking an extremely small detail so please forgive my ignorance on the subject matter. Im just wondering why my retina screen on the laptop only gets 90% sRBG and the Dell gets roughly 85-90%. I have not adjusted any settings on the Dell, aside from setting the brightness to the recommended 120 (forget what unit of measurement is referenced). I have not adjusted contrast, set it to a specific media profile etc...
Nogo
Gallery: 17 photos
Joined Dec 2013
Feb 19, 2015 12:33 |  #6
You should be getting almost 100% sRGB. The percent you are stating sounds like the percent you should be getting for aRGB.
I hate to ask, but the figure you are stating is not for aRGB instead of for sRGB, is it?
Philip
gnome ­ chompski
Joined Jun 2013
Feb 19, 2015 13:11 as a reply to  @ Nogo's post |  #7
Im pretty sure its sRGB but I will double check tonight.
pulsar123
Gallery: 82 photos
Feb 20, 2015 12:03 |  #8
Could also be a fault of your calibrator. Which model do you have? With my basic colorimeter (ColorMonki Smile), I typically get ~95% sRGB with all my monitors, which I suspect is at least in part due to the colorimeter itself (it is not rated for wide gamut monitors).
6D (normal), 6D (full spectrum), Tamron 24-70 f2.8 VC, 135L, 70-200 f4L, 50mm f1.8 STM, Samyang 8mm fisheye, home studio, Fast Stacker
gnome ­ chompski
Joined Jun 2013
Post edited over 8 years ago by gnome chompski.
Feb 20, 2015 12:17 |  #9
pulsar123 wrote in post #17440897 (external link)
This is the calibrator. that I have:
http://www.amazon.com …age_o03_s00?ie=​UTF8&psc=1 (external link)
-dave-m-
Gallery: 6 photos
Joined Sep 2011
Feb 20, 2015 21:30 |  #10
gnome chompski wrote in post #17440920 (external link)
I use the Spyder4 Pro, same meter as you have, I consistently get 99% sRGB on both of my Asus PA248 monitors(two different PC's). I get 92-93% sRGB on my laptop which has a mediocre LG 1080p panel.
5D MkII Gripped | 7D MkII Gripped | 200 f/2.8L | 17-40 f/4L | Σ 24-105 OS f/4 Art | Σ 50 f/1.4 Art | Σ 150-600 OS f/5-6.3 C | 430EX II
CeGe
Joined May 2012
Mar 07, 2015 17:06 |  #11
Did you notice a big change after calibration of the U2715H? The spec sheet said that it comes calibrated from Dell, but I have my doubts about that.
gnome ­ chompski
Joined Jun 2013
Mar 08, 2015 19:36 |  #12
it wasnt bad straight from Dell, but it was way to bright. I honestly have not attempted to recalibrate since I started thread
6,219 views & 0 likes for this thread, 7 members have posted to it and it is followed by 3 members.
1455 guests, 128 members online
