Thread started 18 Feb 2015 (Wednesday) 09:18
Standard or Wide Angle Ring?
DGStinner
Gallery: 24 photos
Joined Jan 2014
Feb 18, 2015 09:18 |  #1
I want to purchase an adapter ring for my Lee Filter system which would fit my EF-S 10-22mm and EF-S 17-55mm. Both are 77mm. Do I need the wide angle adapter ring or would the standard ring work without causing vignetting?
BigAl007
Gallery: 556 photos
Feb 18, 2015 16:15 |  #2
Given that the 10-22mm is an ultra wide angle for the format I would be going with the wide angle version, you will probably need it. If the difference in cost was not significant I would always pick the wide angle version where I could.
Alan
DGStinner
Gallery: 24 photos
Joined Jan 2014
Feb 18, 2015 20:41 |  #3
Thanks. It looks like the wide angle ring is twice the cost of the standard.
BigAl007
Gallery: 556 photos
Feb 19, 2015 11:30 |  #4
Just had a look and it seems that you will need the wide version for both your lenses. The wide version is recommended for lenses wider than 35mm (I guess on FF) so your 17 with an FF eqv field of view of 28mm is well within the recommendation for the wide version. At least both lenses have the same size filter thread, so you only need the one ring.
Alan
tagnal
Post edited over 8 years ago by tagnal.
Feb 20, 2015 13:55 |  #5
Definitely get the wide angle one. I bought the foundation kit and the standard ring from someone. Using it on my 17-40, you could easily see it in the frame on the wide end. the wide angle one works perfectly.
5D3 / M3 / S100 / Σ 35 Art / 50 1.8 / 135 L / 17-40 L / 24-70 L / 70-200 f/4 IS L / m 22 2.0 / 580ex II
Toy List | flickr (external link) | FAA (external link)
1,036 views & 0 likes for this thread, 3 members have posted to it.
1507 guests, 133 members online
