Thread started 19 Feb 2015 (Thursday) 21:21
Lightweight macro flash options.....
PIXPHATIC
Gallery: 28 photos
Joined Sep 2014
Feb 19, 2015 21:21 |  #1
Hi,
Have tried different options of diffusers for taking small insects macro….all of them DIY stuffs…but more or less effective. But my problem lies with the huge weight of the non ETTL/manual flashgun itself ( a four battery with GN 60)..…..(even damaged a DIY rig due to it’s weight) .
Is it possible to use a small flash like the Canon 90EX, mounted in front of the lens somehow ( at present don’t know how……) at an approximate angle of 45 degrees…??
The dedicated twin flash system is out of my budget and do not like to use any of the ring flashes……due to the weird ring reflections and more importantly since they cannot be used with the ET-67 hood on my Canon 100f2.8 lens……I fancy taking macro shots with the hood on.
Till now I have adjusted the flash power manually and taken most the shots on manual mode,with MF.
Also looking for some even smaller flash options…. a set of 2 could be used on a rig.
Have gone through some good-looking options like these
https://photography-on-the.net …showthread.php?​p=17390508
available online…but unfortunately they are not available here in India.
Advice sought
Thanks all.
Photography my religion,World my Tabernacle.
Canon 70D,Canon 500D(for macro & back-up),Tamron 150-600mm,Canon 100f2.8,Canon 50mmf1.8II(nifty-fifty),Canon 18-55 kit lens,Kenko 300 Pro DGX 1.4X C-AF TC,SLIK 700 Pro DX,Manfrotto 498 RC2,Lowepro Prorunner 350AW & 450 AW,Opteka 25mm C-AF Extension Tube........& obsession for photography..........
Gary ­ Wiant
Joined Sep 2009
Feb 19, 2015 21:38 |  #2
Check out some led ring lights, I just bought a Pergear Macro 232 LED ring light on eBay for just under $100 what I like about this one is it has a variable power that you can adjust from 20% - 100%, it has rechargeable lipo battery, and best of all to me it's not a "flash" the light is on from the time you turn it on until you turn it off so you can see the expose the entire time you are composing the image.
Gary Wiant
R6 Mark II - Eos- M - RF 28-70 F2.0 - RF 70-200 F2.8 - RF50 f1.8 - EF 17-40 F4 - EF100 2.8 Macro - EF EOS RF Afaptor - M22mm - M18-55 - Canon Ef-Ef-s to M converter - 1.4x VIII & 2x VII extenders - 540EXII Flash, Flash Zebra SF-18 Ext. Battery Pack, Kenko Extension Tubes - Manfroto Macro Bracket - Lensalign Flickr (external link)
orionmystery
Feb 19, 2015 21:43 |  #3
I, too, prefer lightweight macro rig. I use a 270EX on hot shoe and concave diffuser for my macro work, something like this.
HTTP response: NOT FOUND | MIME changed to 'text/plain'
20121217_233132-copy (external link) by Kurt (orionmystery.blogspot​.com) (external link), on Flickr
Mine is 70D/40D, 60mm F2 though the diffuser and bounce are similar.
More info: http://orionmystery.bl​ogspot.com …12/melvyns-macro-rig.html (external link)
More ideas for macro rigs: http://orionmystery.bl​ogspot.com/2010/12/mor​e-macro-rigs.html (external link)
Kurt
Malaysia & Borneo herping/macro tours:
http://www.orionherpad​venture.com (external link)
PIXPHATIC
Gallery: 28 photos
Joined Sep 2014
Feb 20, 2015 09:07 |  #4
Thanks friends....
Got a cheap replica of the 270EX.....now to mount it on something. Also need an extension cord.
Would keep the post updated.
Cheers...!!!
Choderboy
I like a long knob
Gallery: 185 photos
Feb 20, 2015 17:07 |  #5
PIXPHATIC wrote in post #17440609 (external link)
Thanks friends....
Cheers...!!!
Lots of ideas on Kurt's page above.
Attaching 270 to your lens hood seems too easy not to try.
Dave
Image editing OK
PIXPHATIC
Gallery: 28 photos
Joined Sep 2014
Jun 17, 2015 23:06 |  #6
Hi all,
Seem to get a macro flash rig just as I wanted.......lightweig​ht,portable,effective.​.....but very very inexpensive.I wanted to get a flash rig without attaching anything to my camera body.The earlier rigs were comparatively heavy,cumbersome.
Also I always prefer to have the hood on my lens.This way I got what I actually wanted. It is made up of 1/2 inch wide & 2mm thick aluminium strips.Without the flash weighs around 50 gms.Effective cost of production around 1$........:-D
The flash is 2 battery inexpensive alternative to 270EX....which is lightweight too.
Only downside is the assembling takes some time ) abt 3-5 mins .....and requires a screwdriver......:cry:
Well I am working on that part now....;-)a
Could not resist posting my newest macro-flash rig.....Got it set yesterday....tested on some minute articles.Sorry for the hazy images.Hope to post some nice shots in coming days after actual field testing.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/06/3/LQ_733188.jpg
Image hosted by forum (733188) © PIXPHATIC [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/06/3/LQ_733189.jpg
Image hosted by forum (733189) © PIXPHATIC [SHARE LINK]
PIXPHATIC
Gallery: 28 photos
Joined Sep 2014
Post edited over 8 years ago by PIXPHATIC.
Jun 17, 2015 23:14 |  #7
One more thing......I always have my 1.4X TC on with my macro lens......so it actually helped me to create the space to put my rig on my lens.....:-)
I put some self-adhesived paper and 2mm thick rubber sheet on that part of the lens and hood touching the rig...so that on frequent assembling and dis-assembling....they are all very safe.
With flash,batteries,connec​ting wires....the set-up weighs around 200gms.That too the weight is evenly distributed between the lens and the hood via the small bridge (on which the flash is actually positioned).
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/06/3/LQ_733190.jpg
Image hosted by forum (733190) © PIXPHATIC [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/06/3/LQ_733191.jpg
Image hosted by forum (733191) © PIXPHATIC [SHARE LINK]
Dalantech
Gallery: 525 photos
Best ofs: 5
Jun 20, 2015 23:57 |  #8
Do you have any sample images with that rig?
My Gallery (external link)
My Blog (external link)
Macro Tutorials (external link)
PIXPHATIC
Gallery: 28 photos
Joined Sep 2014
Jun 21, 2015 01:38 |  #9
I went out today with my new rig.....took some shots.
Shared herewith.....
1.
IMAGE: http://i1278.photobucket.com/albums/y513/PIXPHATIC/_MG_4560%20copy_zpsheympwx3.jpg
IMAGE LINK: http://s1107.photobuck​et.com/user/PIXPHATIC/​library/  (external link)
Photo by PIXPHATIC (external link) by PIXPHATIC on photobucket
2.
IMAGE: http://i1278.photobucket.com/albums/y513/PIXPHATIC/_MG_4578%20copy_zpsx5e8nb1g.jpg
3.
IMAGE: http://i1278.photobucket.com/albums/y513/PIXPHATIC/_MG_4589%20copy_zpsyr5ft0m2.jpg
4.
IMAGE: http://i1278.photobucket.com/albums/y513/PIXPHATIC/_MG_4586%20copy_zpsgsrzdavz.jpg
Happy clicking....
Dalantech
Gallery: 525 photos
Best ofs: 5
Jun 21, 2015 06:43 |  #10
Looking good, although the specular highlights look a little "hot". Try either getting the diffuser close to the subject, make a bigger diffuser, or both.
7,065 views & 3 likes for this thread, 5 members have posted to it.
1098 guests, 120 members online
