kalahmarie wrote in post #17445651
Hello all,
I would welcome some much needed advice. I've been using my 580 ex flash on camera for all of my weddings, but would like to add some off- camera flash to my reception setup. I know I will need another flash, but as I've been looking for wireless triggers I've been extremely confused about what to get. Also, should I use a softbox or would I also bounce my flash that's off camera? Thank you for your advice!
I use a Canon 6D.
Every reception is a bit different in how you light it. Depends on the room, the distances, the color of the walls/ceiling, how high the ceilings are, the color of the ambient lighting, etc etc. It also depends on the style you are going for in your image. You could bounce your off camera flashes off the walls and ceilings, but that will illuminate a much larger portion of the room. If you want more dramatic lighting on just your subjects and let the people in the background (sitting at tables) fall off into more darkness, you need more direct lighting on a specific area (dance floor). I've found that using modifiers in receptions are not very practical for me. Big, harder to place without being very noticeable, and you lose a lot of light with them. Especially if you have distances you need to cover.
I've been happy with the Yongnuo triggers. (622cs specifically). But, you may be able to save some money going the manual only route. During receptions, I use them in manual only anyways.
