I am a nature photographer, & have been asked to shoot an indoor wedding. Where should I start with my manual settings? Should I shoot with a prime set lens, or my 18-55mm? (I shoot with a Canon Rebel T3.)
okrainphotos Hatchling 5 posts Joined Nov 2014 Location: Oklahoma More info | Feb 23, 2015 14:56 | #1 I am a nature photographer, & have been asked to shoot an indoor wedding. Where should I start with my manual settings? Should I shoot with a prime set lens, or my 18-55mm? (I shoot with a Canon Rebel T3.)
mclaren777 Goldmember 1,482 posts Likes: 86 Joined May 2012 Location: Olympia, WA More info | Feb 23, 2015 15:32 | #2 I hate to sound rude, but it sounds like you're probably not ready to be photographing an indoor wedding. A simple comparison of sensor technology: Nikon vs. Canon
frugivore Goldmember More info Post edited over 8 years ago by frugivore. | Feb 23, 2015 15:41 | #3 A flash will help tremendously. So will a fast prime lens.
CoRNDoGR6 Senior Member 338 posts Likes: 17 Joined Dec 2009 More info Post edited over 8 years ago by CoRNDoG R6. | Feb 23, 2015 15:46 | #4 There's so much advice to be given for photographing a wedding. But for starters, listing what gear you have can help others steer you in the right direction. Hope you the best. Robert
hbomb69 Senior Member More info Post edited over 8 years ago by hbomb69. | Feb 23, 2015 15:46 | #5 1. 1/80th Shutter (For all lens upto 70mm and for any IS lens upto 200mm) CANON 5D MKIII x 2 / CANON 50D / CANON 550D
picturecrazy soft-hearted weenie-boy 8,565 posts Likes: 780 Joined Jan 2006 Location: Alberta, CANADA More info | Feb 23, 2015 20:14 | #6 If you are asking this question in the first place, the best answer I can give you to what settings you should use for indoors... that would be P. -Lloyd
josh5k Senior Member 360 posts Likes: 28 Joined Feb 2009 Location: Bangalore, India More info | Mar 09, 2015 04:10 | #7 picturecrazy wrote in post #17446564 If you are asking this question in the first place, the best answer I can give you to what settings you should use for indoors... that would be P. Forget manual!! SERIOUSLY! Put a 580/600 on your cam, point it at the ceiling, switch to P mode, and the only thing you have to worry about is ISO. I'm not even trying to be a jerk, this honestly what I tell just about everyone who is starting in weddings. Very true. Technology has come to an extent where you can trust it rather than fidget around. If you are very comfortable with camera settings and just have issues in getting the lighting right, then place it on Aperture priority and the flashes on TTL. Then you get to play around with ISO and Depth of Field while the tech will take care of the lighting for the most part. CameraLogy.Com
| Latest registered member is IoDaLi Photography 1747 guests, 132 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
