Thread started 23 Feb 2015 (Monday) 22:05
Trying to trigger studio strobe with yn622 triggers
kenwood33
Feb 23, 2015 22:05 |  #1
I have this cable below which connects to the yn622 trigger on one end and an alienbee strobe on the other. However it won't fire the strobe light. What is the correct cable to use to fire alien bee lights?
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/02/4/LQ_714556.jpg
Image hosted by forum (714556) © kenwood33 [SHARE LINK]
Gearlist
bumpintheroad
Self-inflicted bait
Gallery: 21 photos
Joined Oct 2013
Feb 23, 2015 22:12 |  #2
That looks similar to the cable I use to trigger my Alienbees from RF-603's. I find that sync cords go bad fairly often. I had a bad one last week. Try another cable.
-- Mark | Gear | Flickr (external link) | Picasa (external link) | Youtube (external link) | Facebook (external link) | Image editing is okay
kenwood33
Feb 23, 2015 22:26 |  #3
I have 4 of these cables and none of them work. I am wondering if I have to set my camera in a certain way or trigger to a certain channel in order for it to fire my alien bees?
Gearlist
CliveyBoy
R.I.P.      He will be missed
Joined Nov 2005
Feb 24, 2015 00:58 |  #4
What are your camera flash control settings? Are you trying to use HSS/Supersync?
Clive, and Great G/D Abbie
50D; 580EXII, 430EXII, 550EX, YN685EX; YN-622C II, YN622C-TX and YN560-TX controllers TOYUG II v5.10 YN622 System Guide (external link)
I tried retiring, but gave it up - it's a dead end
windpig
Chopped liver
Feb 24, 2015 06:11 |  #5
Did you try firing using the test button on the transmitter?
Go ahead, spin the wheel.
kenwood33
Feb 24, 2015 07:48 |  #6
I tried both Ettl2 and manual on my camera (5d2). HSS not set. Pressing the test button doesn't fire the strobe (works on regular flash 580ex2).
Gearlist
windpig
Chopped liver
Feb 24, 2015 08:06 |  #7
Just to be clear, the test button works when you have a 580 on the receiving end? Hmmmm, I know somebody that is using the YN662Cs with a set of Einsteins.
kenwood33
Post edited over 8 years ago by kenwood33.
Feb 24, 2015 08:08 |  #8
Correct, the test button on the yn622 works fine on both of my 580ex2.
Gearlist
Left ­ Handed ­ Brisket
Gallery: 15 photos
Joined Jun 2011
Feb 24, 2015 08:14 as a reply to  @ kenwood33's post |  #9
The 1/4 to 3.5mm adapter on one of my cords was bunk on arrival. Maybe that's the problem?
rebelsimon
Joined Nov 2013
Feb 24, 2015 08:26 |  #10
I use YN622's to fire strobes. Settings in-camera shouldn't really have any effect on whether or not the strobe fires, definitely seems like a connection issue. I use a simple adapter/cable that came in the box with my Mettle strobe (nice surprise).
I would try a different adapter before I gave up on the YN622's, they've proven really useful to me as I often mix speed lights with a strobe, and I love that they will hyper-sync with most studio strobes, no ND filters necessary to shoot wide open.
Toronto area photographer http://www.SimonMellic​kPhotography.com (external link)
Cameras:5Diii (x2), 70D
Lenses:Rokinon 14mm f2.8, Voightlander 20mm f3.5, Canon 24-70 f2.8ii, Tamron 35mm f1.8 VC, Canon 50mm STM, Tamron 90mm 2.8 VC, Canon 135mm f2
Lights: AD600, AD200 (x2), V850 (x4)
kenwood33
Feb 24, 2015 09:37 |  #11
rebelsimon wrote in post #17447231 (external link)
Does Hyper Sync= High speed sync (HSS)? Do you simply set HSS on camera and fire your strobe? or is there more settings to it?
Gearlist
cc1995
Joined Dec 2012
Feb 24, 2015 10:56 |  #12
I have been using these with my 622C triggers with no issues to connect to my AB800's. Never had an issue. Inexpensive as well. Just connect one to my 622 trigger and plug it into the sync jack on the Strobe.
http://www.amazon.com …_385040_1215283​60_TE_dp_1 (external link)
rebelsimon
Joined Nov 2013
Feb 25, 2015 19:58 |  #13
kenwood33 wrote in post #17447329 (external link)
Hyper-sync is slightly different. HSS "pulses" to extend the flash duration. Hyper-sync takes advantage of the after-glow from the strobe firing. But with the YN622's you just set the in-camera menu to HSS and chimp away.
3,334 views & 0 likes for this thread, 7 members have posted to it and it is followed by 3 members.
1680 guests, 138 members online
